Tow hitch cover dome.
Has liked: 1470 times
Been liked: 1642 times
This is something I discussed with Sarah at the Shepton show - nice to meet you by the way :)
Having tried "stealing" the dome from a door knob - well it seemed like a good idea at the time :oops: , I ended up buying a radius turning tool for my C3 lathe.
These are the parts as they arrived:
They're covered in red grease so need cleaning before use - don't use Methalated Spirits - it attacks the red paint :shock:
Fitting to the lathe requires the removal of the compound slide:
Once the turning process is finished the bar looks like this:
My lathe needs a little TLC, so the end finish isn't the best but it cleaned up well with a little emery cloth.
Sharp eyed viewers will see I had to "engineer" a solution to hold the part, having cut the bar too short for the tool - I had forgotten how far the bar needs to extend so that the tool doesn't interfere with the chuck :oops:
Parted off and cleaned up, the finished dome is thus:
Next job is to cut out and shape the backing plate.
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Hi Adrian,
I don't mean to try and steal your topic or question your work but...
would anyone be interested if I were to cast one of these out of Aluminum?
Just wondering
Brian
Brian
David Makaras
Post by David Makaras »
Hi Adrian,
So that is how it is done on a lathe. Fascinating.
Thanks for the pics...
David Da Costa
Post by David Da Costa »
I did mine on my CNC Milling machine.
http://www.armortek.co.uk/forum/viewtopic.php?t=2203
