Pz III and Panther Deck Hinges and More
Mike Stannard (toyrific)
Post by Mike Stannard (toyrific) »
Hi Guys
Here are hinges for the Pz III and Panther. Plus pictures of the production parts of the Pz III Start Crank and Cleaning Rod Set.
PZIIIT07 Start Crank (Panzer III Ausf A-N) $35.00
PZIIIT07K Start Crank (Panzer III Ausf A-N) Kit $20.00
PZIIIT16A Cleaning Rod Two Piece Aluminum Ends (Pz III N) $70.00
PZIIIT16AK Cleaning Rod Two Piece Alum Ends (Pz III N) Kit $45.00
PZIIIT16B Cleaning Rod Two Piece Brass Ends (Pz III N)
$80.00
PZIIIT16BK Cleaning Rod Two Piece Brass Ends (Pz III N) Kit $55.00
Hinges for the Panzer III, Panther and others.
These hinge sets come in de-mold condition and will require clean up. Hinge pins are not included as there a options of the type of pin to use. Angle pins that match the slope of the side, flat ended pins and hollow tube pins. The basic hole sizes for pins are 1/8" on the large hinges and 3/32" on the small hinges, these sizes vary a little due to white metal shrinkage. Depending on the type of pin you use, steel dowels, brass or aluminum rod or tubing you may need to drill out holes slightly.
I have not cast bolt holes in the hinges, for those wishing to use nuts and bolts for assemble the holes can be easily drilled and countersunk. I recommend using flat head socket screws as these are the right shape and appearance of the real bolts, all you need to do is fill the hex wrench hole before painting.
My thanks goes to Tim Bowman how generated the masters for the hinges.
PZIIIT26A Front and Rear Deck Hinge Set (Pz III Ausf J to Early L) $80.00
PZIIIT26B Front and Rear Deck Hinge Set (Pz III Ausf Late L to N) $60.00
Pan28 Panther Rear Deck Access Cover Hinge Set of 2 $12.00
Gent031A Large Tank Deck Hinge (Panther and others) $6.00
Gent031B Small Tank Deck Hinge (Pz I, II, III and others) $5.00
All parts available for order.
Please e-mail orders.
Mike
