Tiger Axle Question
Rocky Sembritzky
Tiger Axle Question
Post by Rocky Sembritzky »
I have read a few posts that suggest that Loctite will not hold the axles in place and cross drilling and inserting a pin is the way to go.
Here in the staes we have Loctite red, blue and green. The red is advertized as permanent and that is a little scary.
I am open to suggestions and advice!
Rocky
Lucien Runge
Post by Lucien Runge »
Rocky;
Use the red loc-tite but only after you have everything set up perfectly. If in the future, you need to readjust something, all it takes is a little heat from a MAPP gas/butane torch and "Badda Bing-Badda Boom", it comes loose.
Lucien
"Say 'ello to my little friend!" - "Say goodnight to the bad guy", Scarface
Tim McCarthy
Been liked: 31 times
Post by Tim McCarthy »
G'day Rocky
Just as Lucien said use the red loc-tite the higher number the better.
I had 2 axles that came loose after my test running on these I pinned with a 2.5mm pin the lock-tite
Also I would suggest you put a retaining loc-tite on were the torsion bars goes into the axle shafts together with a lock-tite on the grub screws that hold the torsion bar on to the axle.
Timbo
