futaba 2.4 G
Dale jordan
Been liked: 512 times
futaba 2.4 G
Post by Dale jordan »
Can someone , please tell me the model futaba set to buy for my models is it the 7C 2.4 .....Dale
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Dale
That seems to be what most use in the UK.
Unless you need more channels
Been liked: 3692 times
Hi Dale
The set that we recommend is the Futaba 7C. This set gives you full function control including blank firer and lights. The budget Futaba 6ex, unfortunately, only has 4 proportional channels. You need one for each track, one for turret turn and one for sound control. All of which means that the gun cannot be fully controlled, its either fully depressed or fully elevated. The 7C is more expensive but has no issues.
We have also tested the our equipment with Spectrum 6 and 7 channel radios and with Sanwa 6 channel gear. Beware of multi channel sets, they are known to have compatibility issues. The new Armortek modules are digital pulse counting devices and do not work well with receivers that produce non standard outputs.
Dave Hill
Post by Dave Hill »
thanks for the heads up mark as at some point i was pondering about which model to get as i would like to use a camera costing
about £40 as advertised in model aircraft mags.
the 6ex wont have enough channels for what i would like to do
Dale jordan
Thanks for your reply Mark .. I'm just about to order one . Just one more question ... is it best to buy the Aeroplane version or the helicoper one . what the differance ??? and no servo ?? ....Dale
Hi Dale
I don't think there is any difference between the two types, apart from the default settings. For tanks we don't use either set of defaults, so you can buy whichever one you like. You don't need any servos.
