Panzer III Cone head Bolts
Sarah Frazer
Been liked: 2 times
Post by Sarah Frazer »
Hi Steve,
I'd be interested in a 100 castle nuts please.
Regards,
Sarah
Has liked: 1477 times
Been liked: 1676 times
I'd be interested to know the pricing for some castle nuts, and also whether they would be suitable for Tiger parts such as the bump stops.
Jim Fowler
Post by Jim Fowler »
Steve,
By my count, I think we have an interest for 500+ of 3mm Castle Nuts.......
What is your opinion?
Thanks,
Jim
steve winstone
Been liked: 46 times
Post by steve winstone »
Hi Jim,
I think there is enough for me to get a batch cast, attached is photos of the 2 types, let me know which one you like and I will send it out to cast. I think the price would be around the same as the cones and wing nuts which is 50p each.
[/img]Image
Image[/img]
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Hi Steve
NICE! Count me in.
Left(top photo), center (bottom photo) gets my vote. :D Thanks for your quick response and effort, as always.
Dale jordan
Been liked: 497 times
Post by Dale jordan »
Hi Steve . I'll have some as well !! will these be cast in brass like the cone heads ?? M 3 OR M 2.5 Thread ? .. Dale
Ian Rodney
Post by Ian Rodney »
Hi Steve,
Count me in too! I've emailed you.
Ian
from Glasgow, Scotland
Martin Diessel
Been liked: 21 times
Post by Martin Diessel »
Hi Steve, I take the same choice as Tim! Top left, bottom center ! martin
Brown Hawkins
Been liked: 33 times
Post by Brown Hawkins »
Hi Steve,
Can I get in for 100 please? I like the top left version that is milled a bit.
Thank you,
Brown
David Da Costa
Post by David Da Costa »
Yep, 100 left version for me please Steve.
Lawrence Godson
Post by Lawrence Godson »
I would be interested in the castle nuts also.
Thanks for making them!
Lawrence Godson
Jim Fowler
Steve,
By site, I would agree with Tim's choices; but, more exactly, the castle nut needs to be around 4mm high (3.96 mm by exact calculation).. And I would like to atleast get 100.
Now, if everyone buys them that has said they are interested...I put your batch at close to 1000. So, I am very confident you will achieve a base order sale.....(YAH!)
Thanks,
Jim
Lawrence Godson
Has anyone had access to a PzIII to inventory the locations and numbers of castle nuts? Other than the vorpanzer on the front hull armor and the bump stop brackets for 4 of the swingarms, I can not make out any other locations in any of my images.
Lawrence Godson
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Steve,
Please count me in for 100, like Tim top picture left, second picture center.
thanks
Brian
Oh, and whats a pence?
Has liked: 1038 times
Castle Nut Quantities
To reply to Lawrence:
I've only been able to look at my photos, so what follows may not be complete.
Pz III castle nut locations:
All cone head bolts used castle nuts on the inside.
Sprocket ring retainng bolts - 12 off each sprocket ring, so 24 per sprocket, 48 in total
Front and rear bump stop mounting bolts - 2 off each stop, 8 in total
Vorpanzer hull - 15 off (larger size?)
Vorpanzer turret if fitted - 16 off)
Lower bracket joining hull upper and lower units. These came in two types, the early scalloped version which was welded to the hull and a later, straight bracket which came with the later production hull without the side escape hatches. These simplified brackets were bolted to the lower hull. I think there are 10 off per side but I haven't got access to the Jentz and Doyle drawings. Someone might check this.
Return roller mounts - 3 off per mounting, 18 in total
Hull lifting hooks - 2 off per hook, 12 in total
Tracket adjuster mounting brackets - 6 off per bracket, 12 in total
Domed cover on the rear lower hull plate - 4 off.
Shock absorber upper mountings - 4 off per mounting, 16 in total
I haven't counted that lot up, but it must come to well over a 100.
Hope that helps. I'll post this on the Pz III section as well.
