Futaba 40 mhz to 2.4 Ghz
Hi Guys
I have a futaba T9CHP super 9 (PCM1024) transmitter. These are the ones with the modules in the back. Has anyone tried a 2.4 module in the back of these, and do you have the item code? or best buys? uk or over sea's.
The question I am wanting to ask is 'do these work okay with just the module in the back'? or is a new 2.4 set better? (which would now be a 10 channel transmitter).
Been looking on sites and they only show a 8 channel module to go in the super 9, so am I right in thinking that I will loose one channel?
Advice would be appreciated.
Richie
Richie
- Mick Regan
- Has liked: 34 times
- Been liked: 6 times
Hi Richie
I think you are right. I appears that Futaba have dropped the 9 channel set-up. It loooks like you will loose a channel if you convert to 2.4. It doesn't even appear to be possible to fit a 10 channel module, and have a redundant channel.
Still, if you stick with 40MHz, there will so few of you, there won't be a problem with frequencies
Mick
Mick
Hi Mick
Thanks for your reply. Been speaking to Ripmax today, the 10 channel module will not work in a 9 channel. The only module which fits it is the 8 channel, so i will loose 1 channel because its not PCM mode. So now I've got a hard decision. Should I buy the module and receivers or do a buy a 12 channel 2.4 and sell mine??????? I need to think hard to get the best deal.
Richie
Richie
- Mick Regan
Hi Mick
they are cheaper over seas 10 channel around £300, and 12channel below
http://cgi.ebay.co.uk/Futaba-12-FGH-FAS ... 19b7db969c
Richie
Richie
- Has liked: 1385 times
- Been liked: 1580 times
- Paul Wills
- Has liked: 646 times
- Been liked: 141 times
Hi Guys
Servo shop has got a good price on 2.4ghz receivers, just got 3 from them on sat, and came at 9am today, wow that was fast, just waiting for my radio now
I will be putting my others up for sale soon, 2 have Thomas encoders fitted, also pcm 9 ch receivers x 3.
Richie(wiggytronics)
r-wignall@sky.com
r-wignall@sky.com
Richie,
The FF9/T9 radio was only ever a 9 channel radio if you had a PCM receiver! And these are as rare as hens teeth. On ordinary PPM it was only ever 8ch.
Us in the SE have quite a few of these superb radios with Futaba 2.4Ghz modules in them, either the TM7 or TM8 (ie 7 or 8 ch) and they work very very well. The FF9/T9 radios are so versatile with umpteen diferent variables you can set up. Also, they are two a penny (well, not quite that cheap!) on Ebay secondhand as people always sell them to upgrade to 2.4Ghz!!!
There are also two or three Chinese companies making 'compatible' 2.4Ghz Tx modules and Rx's but I've no experience with these. Although more expensive I think I'd stick with the Futaba originals just in case.
