Introduction
Bodo Langbehn
Been liked: 25 times
Introduction
Post by Bodo Langbehn »
Hello together,
I want to introduce me, my name is Bodo Langbehn and I live in Germay. At the moment I have began to build the SdKfz 222. Over 20 years I have built several tanks in scale 1/10. A few years ago I have changed to 1/6, on my workbench is a scratch built Panther A and a SdKfz 7 Halftrack from Armortek. I have to check out how to post pics, to show you the progress of building the 222.
Bodo
leesellars
Been liked: 15 times
Post by leesellars »
Hello Bodo
Welcome to the Forum. There is a lot of helpers out here all you have to do is ask a question.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Kent Wiik
Post by Kent Wiik »
Hi my friend!
Oh so good to at last see you here among us Bodo :D
Pleased to see another of all those stunningly skilled German builders...
I have told about you in my Panther saga so some of us know about your skills in this.
Your Panther Ausf A is the best 1:6th RC Panther on the planet!
As a scratch build it is an amazing model, please show us more of it.
I am sure you will find this forum a great place to be part of and not only as guest as before.
A very warm welcome Bodo
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Welcome Bodo!
I am looking forward to your posts very much. Your Panther is simply incredible.
Kindset regards from California
Kent Wiik
Post by Kent Wiik »
Just noticed the link to Bodos Panther in my Panther saga doesn’t work any more... :?
So until Bodo find out how to post photos here I show some of them.
I think they speak for themselves and bare in mind it is scratch build.
Enjoy!
:shock:
/Kent
Roland Mann
Been liked: 19 times
Post by Roland Mann »
Welcome Bodo. I agree with Kent your Pather is fabulous. OK I have seen more of your work as other members in the forum. However with your appearence here we all will have a chance to watch your excellent results.
Wegen den O-Ringen werde ich mich nochmal bei Dir melden.
Best regards Roland
Der Weg ist das Ziel.
Has liked: 161 times
Been liked: 830 times
Bodo,
Welcome to the forum. Like others have said your Panther A is fantastic. A credit to you and your machining skills. Beautiful work. I would like to see more pix.
I look forward to your posts and thoughts on the Armortek models as you build them. Thanks Kent for posting photos,
Kind regards,
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Beautiful job!
Are those track links metal, cast?
Thanks for sharing,
Brian
unlimted skill,builds like this do need to be seen,very clever.thanks for coming on bodo. simon manning
Sven Strobbe
Been liked: 11 times
Post by Sven Strobbe »
Bodo
Welcome to the Forum...
Seeing the pictures Kent Posted and having said its all scratch build... :shock:
Very beautifull, hoping one day i'll be able to reach your level of skills...
Sven
It's a beautiful day to go out in my King Tiger
Pierluigi Patri
Been liked: 1 time
Post by Pierluigi Patri »
Hi Bodo,
Welcome to the Armortek's Forum.
I appreciated your work on the Panther.
Pierluigi
Bodo Langbehn
Hello to all of you,
at first I want to say thank you for the very warm welcome you have given to me, and especially to my friend Kent for posting some photos from my Panther. It makes me a bit proud when I read the comments about my Panther, because I think the level in this forum is very high.
Yes the Panther is my own construction. I have made most of the parts of my own, except a few parts, which were to big for my mill and lathe.
The tracks were made in investment casting and the material is Alpaca.
The weight is about 140kg, the Panther has a double torsion bar suspension, which works very soft. I have built a three-gear-overlaptransmission and the drive motor has 750 W and it works with 24V. The steering motor is a starter motor for modelengines. The max. speed in the third gear is about 8 km/h.
If somebody want to know more about the Panther, please feel free to ask.
Bodo
Fabrice Le Roux
Been liked: 14 times
Post by Fabrice Le Roux »
Bodo,
Outstanding model, sir.
Did you achieve the scale suspension travel (approx 83mm) with the double torsion suspension? Could you show us how this was done and with what diameter torsion bars/yoke deflection?
Your nickle-silver tracks are also a joy to behold. Do you plan to run the model on them outside ( in a garden or field), or are they for light/indoor use only? The prices I have been quoted in the UK for such limited run investment castings have been very expensive, do you recall what you paid for your tracks?
Please forgive my barrage of blunt questions!
Fabrice Le Roux
Bodo Langbehn
Hi Fabrice,
I didn`t measure the suspension travel, but I think it is about the 83 mm.
The construction is very simple made, the torsionbar from the swing arm is fixed on the opposite side in compensator like the original and the second torsionbar moves from the compensator backwards to the swingarmside.
The diameter from the 1st, 2nd, 7th and 8th swingarms are 5mm, 3rd to 6th are 4,8mm.
I don`t have any problems to let the model run outside, therefore I have built it, the tracks are very restitant to abrasion. I let the tracks cast a couple of years ago and I think the price was arround 1800.-€.
At this moment I am not able to post pics, If you would send me your email adress I could mail you the pics from the suspension.
Regards Bodo
