Elevation mechanism
Andy Payne
Been liked: 2 times
Elevation mechanism
Post by Andy Payne »
Just setting up the elevation gear on my tank and question the weight imposed on the bracket and in particular the shaft of the elevation motor.Has anyone set up a counter balance to compensate for this weight or is it unnessesary.
Andy.
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Andy
I am going to use a counterbalance weight as I am not having
the blank fireing unt on my Panther. Mark gave me a weight value
of abour 3.5 kg which is what the blank unit weighs...
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Andy,
I think you will find that the elevation motor will have little problem coping with the barrel weight. Just make sure that you firmly tighten the grub screw that holds the thread onto the motor shaft, as mine has pulled out on two occasions. A counterweight is a good idea but I've found that the standard turret turning motor supplied with the early Tiger kits is a little marginal on power, so I made every attempt to keep the turret as light as possible.
Allan
Allan Richards
Been liked: 3698 times
Gentlemen
Alan is correct on all counts. The elevation motor is more than capable of handling the weight. Having said that a balance weight will reduce the load. We also felt that the turret turn motor was a bit underpowered and have specified a new motor for the late tigers. More details of this and other major improvements to the option packs will follow soon.
Mick Regan
Has liked: 34 times
Been liked: 6 times
Post by Mick Regan »
Hi Mark
Will the new turret turn motor fit the existing motor mount? I f not, will you be offering it as an upgrade to existing Tiger owners?
Mine worked fine originally, but with the addition of the blank firer, zimmeritte, and all the extras it seems to be underpoweCheers
Mick
Hi Mick
The new motor uses a new mounting bracket and this fits the all earlier model production. We will be offering an upgrade option.
Allan Richards
On my early Tiger I chose to replace the electronic switchng unit with an Electronise ESC however the turret turn speed is not that proportional as the motor needs to have full power/speed before the turret starts to turn. A more powerful motor would get better speed control.
Having said this I am not sure if the actual tank had proportional turret turn speed.
Allan Richards
Joe Boylan
Post by Joe Boylan »
HI MARK - Keep me posted on the new motor - it's for a early version.
I hope the new turret turn motor will fit the existing motor mount, if not please upgrade the mount for a early version too.
JOE BOYLAN
Martin Cohen
Been liked: 1 time
Post by Martin Cohen »
Ditto, for my mid-production Tiger I :)
