Hi..The axle on the LH side next to the rear idler keeps working loose?..
any ideas why or is it just a case of using a strong loctite?..thanx..Mark
Early Tiger Axles Working Loose?
- Has liked: 4 times
- Been liked: 246 times
- Been liked: 15 times
Hello Mark
For the axles you must use Loctite 638 High strenth stud lock. Also have you put decent flats on your torsion bars??
lee
lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
