2024 Sdkfz 7 - First time build
Andy Walker
Has liked: 110 times
Been liked: 104 times
Re: 2024 Sdkfz 7 - First time build
Post by Andy Walker »
Colin Stevens wrote:
Tue Mar 25, 2025 5:33 pm
After spending a many happy hour cleaning and priming, here is the start of the upperworks. Yes, I know I shouldn't be doing this until the motion pack is here, and the motors installed, but as I am going to add some rivet detail, (really shouldn't look at other peoples work) I wanted to see how it was all going to come together. My hope is that I can do the rivets, fix the the body sides on to the deck/body rear/front bulkhead and mudguards, blend it all in, prime and then bolt the whole assembly down on to the chassis. The assembly in the photo is only held down by a few nuts and bolts to check for fit/alignment, I will see what access is like for the nuts to chassis fixings when I remove it.
Any tips on how to close the ga at the front, I have tried "sneezing" the side on to the mudguard but it isn't having none of it.
You could use Milliput...fills just about anything.
