Sorry guys, me again. She has been off her build stand for the first time today. Drove her down the ramps up four steps and to the end of the garden and back again.
My question is how do I determine how tight the tracks should be. I don’t want to under or over tighten them. The last thing I want is to damage them.
Your help again would be much appreciated.
Thanks Martin.
Leopard 2A4 track tension
- Has liked: 40 times
- Been liked: 108 times
- Has liked: 11 times
- Been liked: 123 times
Re: Leopard 2A4 track tension
Martin, the build manual states between 10 & 20 mm deflection in the tracks. I presume this is measured on the middle of the top run.
Hope this helps.
Steve.
Hope this helps.
Steve.
- Has liked: 25 times
- Been liked: 62 times
Will have to check this also, ran down the ramps yesterday and around the Cul-de-sac to see how it looked, lots of twisting and turning with no lose end caps, think the mod worked ok.
now for the rest of the build.
Martin.
Martin.
- Chang
- Has liked: 16515 times
- Been liked: 487 times
Hi Steve , can you explain more about your answer please.Steve McEvoy wrote: ↑Sun Oct 13, 2024 5:21 pmMartin, the build manual states between 10 & 20 mm deflection in the tracks. I presume this is measured on the middle of the top run.
Hope this helps.
Steve.
I am confused about what does "10 & 20mm deflection" and "on the middle of the top run" means.
Thanks and best regards,
Lerh Chang
- Paul Sparkes
- Has liked: 94 times
- Been liked: 236 times
We have lots of hours running on the leopard now, and I'm still adjusting the track tension to get it right.
Tighter seems to keep the tracks on the sprocket better but loose runs smoother, so we run on the tight side, but I haven't measured it.
Just run and look at whats happening if it looks loose tighten it etc. Also they will loosen/stretch when run.
222 scout car
222 scout car
Hi Chang, By 10 -20mm I'm pretty sure they mean put a ruler upright in the centre of the tracks with the tank on the ground the measure how much you can lift the top run of tracks and it should be between 10-20 mm. This is just a base setting. As Paul said run it and see, if it looks too loose or jumps the sprocket tighten them a bit at a time until you get smooth running.
