Which stick does what
Martin Donnison
Has liked: 38 times
Been liked: 99 times
Post by Martin Donnison »
Hi guys new to tanks and with all radios they want you to fly.
Could someone please tell me what sticks do what.
I would be interested to know how you have your tanks setup. Which pot, which channel
I would like to setup for single stick drive and steel and use the other stick for turret rotation and main gun elevation.
Thanks for you help.
Has liked: 1370 times
Been liked: 1567 times
Re: Which stick does what
Left stick is turret traverse and elevation. Right stick is drive and steering.
I've converted to using two pushbuttons at the back to emulate a three way switch.
Anything else like smoker element control or lights gets added to a switch as needed.
Andre Meylan
Has liked: 511 times
Been liked: 227 times
Post by Andre Meylan »
Adrian Harris wrote:
Sat Oct 05, 2024 8:42 pm
It all depends on which mode you are used ... I come from helicopters and flew "mode 2" ... so my setup will be exactly opposite to what Adrian (sorry mate) said ... at the end it does not matter as long as the model does what you want to steer ...!!! :mrgreen:
Best regards, Andre
I guess it also depends if you're right or left handed. I'm right handed, hence I use the right stick for driving.
One of our group has all his transmitters set for left stick driving, so I always end up depressing the barrel when I want to move forwards...
Gerhard Michel
Has liked: 3 times
Been liked: 643 times
Post by Gerhard Michel »
My preferred solution is mode 4. This means the tank throttle is channel 1 (left stick up / down), and the steering is channel 4 (right stick left / right). Therefore the turret moving is channel 2 (left stick left / right) and the gun elevation is channel 3 (right stick up / down). Gun shooting with recoil is the 'fire knob' at the left stick, machine gun shooting is the 'fire knob' at the right stick. Both functions are mixed in the TX to channel 5. Channel 6 is the stepless brake channel for downhill driving with EMF, channel 7 serves a combined 3 way switch for engine start (switch) and WAV player on / off (pushbutton). Channel 8 serves another 3 way pushbutton for song up / down. The channels 9 to 16 serve things as the stepless volume control (real important when using amplifiers of 200 watts and more), the light (front and rear), the horn and some 'radio messages'. For controlling this features i'm using 3 way pushbuttons, 3 way switches or combined 3 way pushbuttons and switches. To get furthermore funktions each button can be used with either a short signal and a long signal for controlling.
Gerhard
Andre Meylan
Sat Oct 05, 2024 10:36 pm
:mrgreen:
Jerry Carducci
Location: The People's Paradise of California, the former Golden State
Has liked: 3 times
Been liked: 1052 times
Post by Jerry Carducci »
Of course I agree with the others- personal preference rules the day. I've used left stick Y-axis for throttle since I began in the hobby,
left stick x-axis for steering right stick y-axis for main elevation and right stick x-axis for turret control.
Everything else depends on the radio and what controls there are are available.
I've been using the FrSky x-20 series of transmitters and there are over 20 physical controls to choose from and the beauty is you can assign any
physical control, switch, button, slider or pot to any channel (or channels) as needed.
Only limit really is imagination.
Sjouke Kooistra
Has liked: 87 times
Been liked: 30 times
Post by Sjouke Kooistra »
Jerry Carducci wrote:
Sun Oct 06, 2024 9:01 am
very much this ... I only need to figure out how to do this still. baby steps in my case :mrgreen:
Stug III no 54 "Helga"
Gerhard Michel
Has liked: 3 times
My choice may look a little strange, but it results from flying model airplanes. The throttle is left, the rudder and the steering for the landing gear are right. The two hand steering in combination with a desk (?) TX and long sticks gives finest control for narrow routes:
Here my modified TX with 'fire knobs' on both sticks. You can also see the telemetry information; here battery voltage, actual current and -first of all- the consumed energy. Other infos are chosable and acoustic warning hints are given automatically.
Gerhard
Andre Meylan
Gerhard Michel wrote:
Sun Oct 06, 2024 10:30 am
Hello Gerhard
Looks serious !!! I intend to using something similar with my Futaba FX-32 ... what I am still curious about is how to start the programming ... do you choose a simple airplane model and the Armortek electronics do the rest ?? That means that smooth steering will just slow one chain and full steering input should make the tank turn on the spot with one chain going into reverse? If not, how to program the mixers?? Is there a working thread in the knowledge base ??
Best regards and schöner Sonntag, Andre
Gerhard Michel
Has liked: 3 times
Hi Andre,
well, to smooth up my steering I'm using another ESC (TVC B-100 from SGS Germany), which gives also the controllable EMF function for variable downhill driving speeds using a seperate channel. Switches and pushbutton functions are combined with TX mixers (a feature of the TX, no additional hardware), some sounds (e.g. turret rotation, gun elevation) are added with RX mixers. Sounds are processed by the versatile Beier sound module, which controls also a variable gun recoil with up to 10 seperate speeds, random sounds and so on (overall up to 96 functions I mean).
The 'fire knobs' are accessories for this TX.
Gerhard
Has liked: 707 times
Been liked: 307 times
Post by Christoffer Ahlfors »
In the beginning, I also didn't know what would be best, so I built the model with selectable one or two stick control (the kind where the left stick controls the left track etc). Immediately, I noticed that it was quite difficult to go straight. Everything else was super easy. The use case for this was that I needed to navigate two doorways very close and at a right angle to get out of the garage. Since those days, I have only used one stick control. Learning to use one stick was pretty quick and I was soon able to navigate the difficult passage without even bothering to switch over, although it was just at the flip of a switch.
The chief advantage of one stick control is that it makes tank driving a "gentleman's sport". That is, you can hold your drink in one hand and do the sport with the other... :P Having one hand free while driving is very useful. You can open gates, hold cameras and what not.
