Phil's Bailey Bridge Build
Phil Dawe
Has liked: 757 times
Been liked: 300 times
Post by Phil Dawe »
When Armortek announced their second batch of Bailey Bridge kits I felt I had to buy one if only to trundle my Centurion and Tiger 1 over. I got stuff into degreasing and priming straight away and drop onto assembly whenever I have a small window in my restoration work schedule at the Battle of Britain Sector Operations Building RAF Northolt. Once you get to the fitting of the transoms patience is a virtue with all of the M3x6 nuts and bolts to be fitted with fiddly access. As the structure grows its amazing how many visitors take an interest in the model and the principles of the real thing.
Steve Lewington
Has liked: 8910 times
Been liked: 334 times
Re: Phil's Bailey Bridge Build
Post by Steve Lewington »
Hi Phil
Its good to see another bridge on the go.
She's coming on well I see what you ment about being a little ahead of tiny a me.
Looking forward to your next post and photos.
Take care
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
Phil Dawe
Post by Phil Dawe »
I was able to do an hour or two more this afternoon on the bridge. I suspect there are more M3 fasteners on the floor than in my storage box for the fixings. Time to get on my knees and pick them up!
Has liked: 2282 times
Been liked: 7196 times
Looking good!
Phil Dawe
Post by Phil Dawe »
A few update photos. Over the past week I have completed the second section. So both will be ready for the wooden planking next week. Fortunately I have lots of Sapele offcuts from a recent project that will fulfil my needs for the decking. This afternoon I started the second ramp.
Phil Dawe
Post by Phil Dawe »
Has anyone else building one of the new batch bailey bridge kits had problem with the fit of the plated pin ENO120 in the joining lugs of the bridge sections? The holes in all of the lugs on my kit are undersize and will have to be reamed to get a nice secure fit for the pin.
Has liked: 1484 times
Been liked: 1690 times
Could it be the primer is enough to make the hole undersized ?
Charles A Stewart
Has liked: 511 times
Been liked: 931 times
Post by Charles A Stewart »
Evening all.
I had to drill mine.
Charles
Phil Dawe
Post by Phil Dawe »
Adrian Harris wrote:
Sun Sep 22, 2024 10:03 pm
Adrian, I made sure the holes were clear. My digital calliper gave me pin diameter 8.01 and hole diameter 7.86.
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Phil
Better to have material to remove than have it way to loose :wink:
Nice job on these bridges guys .
Regards Derek
Steve Lewington
Hi Phil
Good morning I had the same issue.
I removed the paint from the holes and gave them a ream nice easy fix.
Spot on better to have to remove material as you can not add it on.
Have a lovely day
Steve and Luke
No respite.
No forgiveness.
Phil Dawe
Post by Phil Dawe »
After a bit of reaming the pins fit nicely and the build continues
Phil Dawe
Post by Phil Dawe »
Today I moved onto the timber decking. Fortunately I had a good number of Sapele offcuts from when i was building blackout shutters for the RAF Northolt Sector Operations Room. At 25mm thick it was possible to rip them down edge on leaving two 11mm strips which were then put through the thicknesser/planer to get the finished size of 8mm thick. I am now putting them though my bench saw to reduce the width to the finished size for width the length.
Phil Dawe
Post by Phil Dawe »
I have now progressed to planking the first section. I am toying with the idea of using a dark wood stain on the wooden deck.
You have to stain it but not to evenly, the odd plank should be slightly different, with the middle being oily maybe?
