Extra Detal Series 1
Forum for discussion relating to the 1948 - 1950 Series 1 4x4 car
Tim Whitehead
Been liked: 3 times
Post by Tim Whitehead »
Has anyone looked in to trying to reproduce the crease in the front wings?
mick whittingham
Has liked: 10 times
Been liked: 226 times
Re: Extra Detal Series 1
Post by mick whittingham »
What do you mean by the crease? The seam between the top section and the wheel arch?
I'm not sure the metal is thick enough to cut a groove that would mimic the joint seam.
Would it be possible to replicate the feature by paint lining it?
Still a long way from body work as yet.
Tim Whitehead
Been liked: 3 times
I think by adding some extra material to the underside of the top surface of the wing it could be doable.
mick whittingham
Has liked: 10 times
Yes anything is do able given enough thought.
Personally I'm not sure the amount of work is worth it, but if a were to attempt it, I think I'd just use a slitting saw to cut the slot not completely through the skin.
Reinforcing from behind would definitely help. Then blend each edge of the cut to look right.
There are several ways to achieve the seam, I look forward to seeing it executed.
