Has anyone had to replace the rubber coupler located in the motor housing between the the drive gear and the motor shaft in either their left or right motor?
One of mine was bad from the start and has now given up altogether and I was wondering whether I'll need to contact the manufacturer for a replacement or if there is an alternative supplier.
motor/drive gear coupler
- Been liked: 3699 times
