Chris,
As Tim and Allan have mentioned, posting from Photobucket should be really easy. I wonder if the website coding/upload process process is slightly different in the US and UK? Hmmm.
I'm assuming your question is how do to post multiple photos into this forum string from P-bucket? Uploading them into photobucket from your PC is a bit different process.
I separate each image string with a return <enter> so that they are nicely spaced out.
Below is how an image string would look in a posting. I have removed a "/" character so that the actual picture doesn't post, but the code can be seen.
The example code below would post three images into this forum thread from Photobucket, my acount "bobmorey", from my "1-6 Panther" gallery of the same photo, Testphoto-smallsample.jpg. If it were a real posting you would want the photos to all be different, so only the file name (Testphoto-smallsample.jpg in this example) would change.
This may be more confusing than helpful. But hope it helps you sort things out.
One final important thing to remember - if I post the above photos using the image thread shown, but then move the photos to a different gallery within Photobucket, the image string will be broken, and will not post the photos properly in this thread. A new image code would then be needed from the new folder location in order to display the photos.
Kind regards,
-Bob
