King Tiger (2013) No 31 is arrived in Denmark
Chang
Has liked: 16566 times
Been liked: 487 times
Re: King Tiger (2013) No 31 is arrived in Denmark
Post by Chang »
Conrad Sharp wrote:
Fri Aug 23, 2019 4:10 pm
I have another question if you guys dont mind, I have just been assembling my KT 2009 (081) and I notice that 2 of the suspension Bump stops are useless as the suspension arms will always collide with each other before they hit the bump stop. See pic below. Is this a known issue? Or have I made a mistake?
Just my 2 cents: Replace the kit's rubber bump pad by a thicker one (eg, a door stop bump) will do the work.
Regards,
Lerh Chang
Conrad Sharp
Been liked: 2 times
Post by Conrad Sharp »
Yes I was thinking similar, just wanted to check I had not made a mistake.
Allan Carlsen
Been liked: 128 times
Post by Allan Carlsen »
Hello Conrad
I was thinking on you have remembered the following instruction (from the manuel page 20 - about Road Wheels)
"Set the suspension arm to hang down at about 35 degrees, and mark the position of the fixed end of the torsion
bar before removing and filing a flat for the clamping screw. Reassemble and tighten down the clamp screws".
Regards Allan
Conrad Sharp
Been liked: 2 times
Yes I did thanks, the issue isn't dependant on the angle of the suspension, its the physical location of the holes on the hull side and the length of the suspension arms, they physically will bump into each other if the go horizontal (i guess unlikely) which because of the location of the bump stop means they will collide before they would ever hit the bump stop (in only 2 of the 4 stops).
I think the issue is the Bump stop is in the wrong position, it should be lower - nearer the suspension arms. Have a look at yours and try and force the suspension to bump onto all 4 bump stops - 2 will, 2 wont.
Allan Carlsen
Hello all.
I have a stange problem in my amplifier module card. One of my wires from one of the speaker had come off. (hadn't seen it).
When I turned on the module card it made a small bang. Can't see what's wrong. There's a light in the power button.
No sound at all. Any tips on what went wrong.?
Regards Allan from Denmark
Has liked: 1484 times
Been liked: 1693 times
Did the wire come loose from the speaker of from the amplifier module ?
If the speaker wires have shorted together then you may have blown the amplifier chip.
Have you checked all the fuses ?
Allan Carlsen
Hello Adrian
Yes I have checked all the fuses, can't see any problems.
Allan
Allan Carlsen
Here is my amplifier module
Allan Carlsen
Hello all
Is it possible to change this chip or did I need a new amplifier module.?
Regards Allan
Has liked: 792 times
One of the semiconductors bolted to the heatsink seems to be disintegrated and the two white wires in front of it seem to have burn marks.
Allan Carlsen
Hello Vince
Thanks - well spotted.
I need a new module. Thanks for all the replies
Regards Allan
It is possible to buy and replace those transistors, as I have repaired these modules in the past, but it does depend if there has been any damage to the circuit board traces.
