Famo sprocket and front road wheel
Adam Maplesden
Been liked: 4 times
Post by Adam Maplesden »
Hi everyone I'm having trouble with the front sprocket and road wheel on my Famo , the sprocket will not allow the front road wheel to turn with the tracks it looks like it needs a spacer were the wheel comes in 2 although the back half of the wheel catches as well.
How have you all over come this?
Many thanks
Adam
Adam Maplesden
Been liked: 4 times
Re: Famo sprocket and front road wheel
This is the sprocket and half of the front road wheel
Adam Maplesden
Been liked: 4 times
Another one
Brian Ostlind
Has liked: 971 times
Been liked: 2066 times
Post by Brian Ostlind »
I vaguely remember mine rubbing but the sprocket and wheel still spinning
florian rudolf
Has liked: 294 times
Been liked: 640 times
Post by florian rudolf »
The rubber can sometimes rub, what I see here is that the sproket is mounted about 2mm too far inwards. The tapper lock should be flush with the axle, so the road wheel runs exactly between the sprockets.
Adam Maplesden
Been liked: 4 times
Thank you and yeah it was when I was running it but I only put it back on just for the photo but the sprocket was in the middle of the road wheel.
florian rudolf
Then maybe you have too small an angle on the roller arm? It fits me, but just barely with strong compression.
Adam Maplesden
Been liked: 4 times
The angle of the arm is fine and the sprocket position is fine.
florian rudolf
One or two mm to the chassis with the sproket. I know its close, but it will work 8)
