sdkfz 7 Flak build
- Has liked: 11 times
- Been liked: 123 times
- Been liked: 1767 times
Re: sdkfz 7 Flak build
Thanks Steve, This is the last of the Dash posts, Finding dials that look o.k. and to scale was tricky, you have to pay attention to detail on these parts, i tried Black faced dials but you could not see them, so i went for a lighter set, not correct but i liked the look. weathering, dash decals to add, i made it to also illuminate, regards simon.
- thumbnail_IMG_4394.jpg (74.97 KiB) Viewed 5866 times
- thumbnail_IMG_4393.jpg (97.09 KiB) Viewed 5866 times
- Has liked: 20 times
- Been liked: 737 times
Thanks Jeff for Posting, i have been chipping away at the build, mainly concentrating on the cab area and windscreen, regards simon.
- thumbnail_IMG_4471.jpg (66.31 KiB) Viewed 5286 times
- Has liked: 8 times
- Been liked: 701 times
- Been liked: 741 times
Hello Simon,
My i ask where do you get these rings for the dashboard and glasses for the decals.
Do you cut out the glass from plastic?
Best regards Yves
Best regards Yves
- Has liked: 915 times
- Been liked: 82 times
yves mouton wrote: ↑Wed May 15, 2024 8:05 pmHello Simon,
My i ask where doyou get these rings for the dashboard and glasses for the decals.
Best regards Yves
And I'd like to know where you sourced the decals for the gauges from, thanks Simon!
Hi all, Here's some photo's of dash details, For most of the Halftracks the coin capsules size i used are 10mm, 14mm, 24mm, this looks about the right scale, They are used for storing coin collections, i just painted a rim on the capsule using my lathe,, you can also buy the correct size inserts for the capsules to give the dials a bit of depth, all these parts are on E-bay and cheap to buy, The main Rev counter dial was from Armortek used from the Famo Decal set, Peddinghaus Decals sell a set for the 1/6 sdkfz 250 which i purchased but are to big and look wrong, These two sheets of Dash stickers seem to be the best on the market. hope this helps, regards simon.
- thumbnail_IMG_4529.jpg (61.52 KiB) Viewed 5049 times
- thumbnail_IMG_4528.jpg (99.81 KiB) Viewed 5049 times
- thumbnail_IMG_4526 (1).jpg (92.02 KiB) Viewed 5049 times
- thumbnail_IMG_4525.jpg (129.35 KiB) Viewed 5049 times
- thumbnail_IMG_4524.jpg (88.59 KiB) Viewed 5049 times
Winters on its way so its time to resume the 7 Flak, i have placed the Dragon quad on the chassis to get some perspective, The size and dimensions, all the best simon.
- P1280569.JPG (223.16 KiB) Viewed 3120 times
- P1280568.JPG (222.19 KiB) Viewed 3120 times
After a bit of a lay-off i have restarted my build, trying to refresh where i left off, Lots of small details added, now to get some panels lined up for fitting, regards simon.
- thumbnail_IMG_5284.jpg (95.32 KiB) Viewed 2338 times
- thumbnail_IMG_5283.jpg (107.47 KiB) Viewed 2338 times
- thumbnail_IMG_5282.jpg (57.37 KiB) Viewed 2338 times
- thumbnail_IMG_5281.jpg (90.23 KiB) Viewed 2338 times
Hi all, i have been working on the Cab front floor, cutting out and making the inspection hatches, on this late war version the hatches are in a different position, to save time on making i purchased these floor compartment handles from Knupfer in Germany,the quality is excellent,, the chequered floor has yet to be installed, next job steering column.regards simon.
- thumbnail_IMG_5291.jpg (87.5 KiB) Viewed 2213 times
- thumbnail_IMG_5290.jpg (75.88 KiB) Viewed 2213 times
- thumbnail_IMG_5289.jpg (78.52 KiB) Viewed 2213 times
- Has liked: 219 times
- Been liked: 200 times
Hi Simon
Looking very nice mate.
Regards Derek
Regards Derek
Thanks Derek for the encouragement, still working on the front cab area, steering column bracket, fuel tap, bulk head cover, all these little items take time to build from scratch and work out the fitting, nice to see the start of all the other 7 builders coming on, regards simon.
- thumbnail_IMG_5328.jpg (72.6 KiB) Viewed 1401 times
- thumbnail_IMG_5327.jpg (84.91 KiB) Viewed 1401 times
- thumbnail_IMG_5325.jpg (59.55 KiB) Viewed 1401 times
- thumbnail_IMG_5324 (1).jpg (96.19 KiB) Viewed 1401 times
Some more items for the front cab, i think this is an adjustable steering column bolster, if someone knows more as to its purpose let me know, i have made one of these before but had completely forgotten how i did it, A tricky little part, regards Simon.
- thumbnail_IMG_5340.jpg (93.8 KiB) Viewed 1134 times
- thumbnail_IMG_5339.jpg (53.98 KiB) Viewed 1134 times
- thumbnail_IMG_5337.jpg (59 KiB) Viewed 1134 times
- thumbnail_IMG_5336.jpg (54.45 KiB) Viewed 1134 times
- Been liked: 72 times
Hello Simon,
what a real awesome build ! Wow
I couldn't resist and so the new SdKfz7 Number 8 is waiting under my bench to get started
Your little but complex Part on the steering coloum is the Positionmarker for the front wheels
Got this in the original spareparts list from 1942, picture attached .
Best regards from Pulheim,
Cheers Uwe
Cheers Uwe
1:16 Models: Kingtiger
