GROUP BUY - LiFePO4 batteries
Posted: Wed Jan 31, 2024 1:30 pm
For a while now several forum members have been using LiFePO4 batteries.
They offer several advantages over Sealed Lead Acid batteries - the most notable being that:
(a) you can get SUBSTANTIALLY longer run time for a similar capacity battery - forum members have been getting full weekends of running or even multiple weekends of running from a single charge. (i.e TankFest without having to worry about running time)
(b) the lifespan is significantly longer (larger number of discharge cycles)
(c) they retain their charge for much longer when disconnected - lead acid drop about 4% a month and cannot be recharged once they have been discharged below a certain level
(d) they are lighter.
The disadvantage used to be cost - they were always a lot more expensive then Lead Acid batteries, but as their price has fallen considerably over the last couple of years combined with the fact that the Lead Acid have been going up in price, we have now reached an economical tipping point.
The above points, combined with the fact that we had a lead acid battery leak inside one of our tanks last week has prompted us to make a move to LiFePO4.
All of that leads me to the point of this post - we have been in touch with a Chinese supplier of LiFePO4 batteries and worked with them to produce a battery that would suit our tanks - i.e the same dimensions as a lead acid battery, capable of high continuous discharge as well as high instantaneous discharge, and high capacity for a weekend of running .. probably more.
We will be buying these batteries for the models in our factory and we are offering Armortek customers (only) the chance to purchase these batteries as part of a Group Buy.
One important point to note is that we are acting as a middleman on your behalf so we will not be offering any warranty on these batteries - we are purely offering to help facilitate the purchase. In the unlikely event that you have issues with the batteries in the future, you would need to go directly back to the manufacturer.
Details:
LiFePO4 battery 12.8V 30Ah
Nominal voltage : 12.8V - 4 cells in series, 2 cells in parallel (uses 32140 LiFePO4 cells))
Nominal capacity : 30Ah
Continuous discharge current: 50A
Short burst discharge current: 90A
Life: 4000 charging cycles
Integrated BMS with overcharge/ discharge protection
Packaging:
Dimensions: 180mm * 75mm * 170mm (for comparison, a Yuasa 22Ah lead acid is 181mm * 76mm * 167mm)
Hard case to protect the cells.
You pay : £99 including VAT per battery (for comparison, a Yuasa 22Ah lead acid is approx £51 incl VAT)
Shipping: Collect from our factory in Otterbourne
Timeline: Shipping from China by sea will be at the end of Feb. We expect to have the goods 2 months after that - so in time for summer running.
These batteries are design to fit all tanks except the Hetzer.
Group Buy terms:
If you want to participate in this Group Buy we will need your response by the 2nd Feb.
- Offer to ARMORTEK customers only
- 50% deposit will be required in advance. If you cancel before collection then you will lose your deposit.
- Collection from the factory. No shipping.
- We are covering our costs with this group buy and not making a profit so we offer no warranty - you are purchasing the products at your own risk and you will need to go back to the manufacturer with any issues.
Details:
Packaging:
Group Buy terms:
