Hi Guys
Does anyone know where I can get an actual charger that fits the Spektrum DX7 ?, I have 7 different chargers here and not one of them fit, I even bought one from E bay that said it did but ultimately doesn't, it seems to just be a funny size pin or something, anyhow I have a KT that I cant move at the minute !!
cheers in advance
DX7 charger
- Been liked: 1 time
- Has liked: 269 times
- Been liked: 324 times
Re: DX7 charger
Do you have a DX7, DX7s or a DX7se ?
A quick google search suggests that the charger is compatible between the first 2 but the se requires a different one.
- Has liked: 1419 times
- Been liked: 1594 times
Re: DX7 charger
Is the socket in the transmitter or does it have a lithium battery with a socket in it ?
I would imagine the charger would be different for NiMh than Lithium.
Re: DX7 charger
Mark- its just a DX7, Adrian its a lithium battery with a charger pin, it actually felt like the hole on the battery wasn't large enough because most of my chargers wouldn't even get through the hole to the pin so I tore away some of the plastic to make a bigger hole but still, nothing seems to fit, is there any other way that you can charge these maybe ?
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1073 times
Re: DX7 charger
Not certain where you're located but Amazon lists many chargers indicated as appropriate for Dx7 transmitters; least costly was $11.00
Surely you can find one somewhere online.
