Depends what you mean by high stress environment.
Each drive motor has a fuse set at 30A. This is more then enough for neutral turns on longish grass or carrying a person around.
If you are planning on exceeding that then you will also need to up-rate all your wiring and the power supply box - and potentially your batteries as well if you are running with a BMS.
The ALL NEW Armortek drive system for tanks
- Been liked: 3568 times
- Has liked: 6 times
- Been liked: 54 times
Re: The ALL NEW Armortek drive system for tanks
I was thinking of using a 24v 20ah Lithium Battery on a Jagdtiger with your new Brush-less motor motion pack I am getting from you. Or does it need more then 20ah of power to last longer? Also what is the max volts that the new Brush-less motor motion pack can use?
- Has liked: 1454 times
- Been liked: 1624 times
That's kind of a given
Space is not at a premium in the JT, I would probably go for 30Ah or 40Ah.
BLDC motors are rated in KV, which is the number of revolutions per volt. Owning and driving a JT, and having been fortunate enough to drive a Tiger with the new system in it, I can assure you that you don't want more volts
