Hi guys
Any one in the UK have or know where I can get hold of some M3 x 8mm Hex headed bolts with a non standard 4mm head?
I think normally the head is 5.5mm.
They are available from Germany but with a crazy shipping cost.
https://www.ts-modelldampfmaschinen.de/ ... 8-569.html
20 Bolts are required.
Thanks in advance.
Wanted - M3 x 8mm Hex Headed Bolts - 4mm head
- Has liked: 459 times
- Been liked: 949 times
- Gerhard Michel
- Has liked: 3 times
- Been liked: 691 times
Re: Wanted - M3 x 8mm Hex Headed Bolts - 4mm head
Hi Malcolm,
may be a friend may alter those bolts from normally 5,5 mm to 4 mm on a milling machine, when only 20 pieces are needed.
Gerhard
Gerhard
- Has liked: 1495 times
- Been liked: 1699 times
- Jerry Carducci
- Been liked: 1120 times
I get my hex hex nuts and screws from MVD. They are terrific. I have also purchased quite a bit from Knupfer as well.
Both companies have excellent pruducts.
MVD https://modellbauschrauben.de/index.php?m=02_1
A more expensive and time consuming alternative was to use my milling machine with the indexing head to mill other suitably
beefy screws to have the standard 5,5mm hex head; useful when I needed a few screws and didn't want to wait for an order to come all the way over from Europe...I made a very simple fixture to screw the target screw into and have at it. Once modified you really can't tell the difference between
these and 'store bought'.
Thanks for your help guys.
Screws ordered plus a few extra
2022 Panther G #15
