Front and Rear Lights
John Studebaker
Has liked: 8 times
Been liked: 7 times
Post by John Studebaker »
M26 Pershing, Taranis X9D transmitter, Channel 7, 2 position switch. (Armortek recommendations for transmitter and receiver.) Lights work - On or Off. However, when On, the front and rear lights flash repeatedly. Is it normal for the lights - front and rear - to flash repeatedly when in the On position? Are there multiple lighting options, i.e., All On (constant); All On (flashing); Rear or Front only; Both Off; etc,? Does the electronic switch in the lighting loom have anything to do with this? If so, what? Any insights are appreciated.
John
Ray Massa
Has liked: 18 times
Been liked: 116 times
Re: Front and Rear Lights
Post by Ray Massa »
John Studebaker wrote:
Sun Oct 22, 2023 3:45 am
John
John,
That is not normal as far as I know. Mine stay on all the time or off. My suggestion would be to take a look at your transmitter settings to see if there is some function that toggles that channel. Otherwise, I would check with Armortek to see if there could be something wrong on the module that drives the lights.
John Studebaker
Has liked: 8 times
Been liked: 7 times
Ray - Thanks for the feedback. I actually had the lights plugged into Channel 6 on the receiver - the Armortek standard. - my misstatement. I checked Inputs, Mixes, Outputs, wiring loom, and wire color connections - all kosher. Not sure I I should have, but I have asked Armortek for some help on this.
John
John Studebaker
Has liked: 8 times
Been liked: 7 times
Mystery of the flashing front and rear lights has been resolved with Kian's help. I did not understand the suggestion printed on the exterior of the light loom package, which basically said to change the servo endpoints of the channel I was using. I'm a Taranis newbie, and the servo reference threw me. By changing the Max value for CH6 on the Output screen from 100% to 90%, 85% and 80%, the flashing light issue disappeared. Thanks Kian.
John
