Battery monitoring with new red modules
Gary Richardson
Has liked: 738 times
Been liked: 1701 times
Post by Gary Richardson »
Hi all
I was chatting to Adrian Harris about battery monitoring and he showed me the set up on his Sturm Tiger :D which uses the older silver modules and a Frsky FAS 100(?) Ampere monitor sending the telemetry via the receiver to his Taranis transmitter.
I am looking at getting a couple of the Frsky FAS100 ADV monitors for my tanks but started wondering about the regeneration the red modules incorporate. Would the regeneration have an adverse effect on the battery monitor. Has anyone used these monitors with the new red modules in conjunction with the Taranis 2019 plus transmitter ?
Gary
Has liked: 1370 times
Been liked: 1567 times
Re: Battery monitoring with new red modules
Are you worried that the back EMF will damage the sensor or affect the readings ?
The silver box modules also do regeneration and haven't affected the sensor.
I can't say what effect the regeneration has on the accuracy of the readings.
I use them to display the maximum current draw and minimum battery voltage readings to track battery health whilst running.
Gary Richardson
Adrian Harris wrote:
Mon Sep 25, 2023 9:05 am
Hi Adrian
Yes, it is the back EMF that concerned me. I liked how easy it was to see on your transmitter when you were running the Sturm Tiger. I will order a couple of the Frsky FAS100 's to put in the Churchill and Tiger. :D
Gary
