Series 1 Number 11,Sound,Motor and light test
Posted: Sat Sep 09, 2023 6:30 pm
by Donald Suttie
Hi All
Jumping the gun here,but always like to check out the electronics before going deep into the build
After a long lay off from programming RC systems i am happy to report i have all 3 systems running on the Series 1 Motor/Sound/lightning kit on a Spektrum NX10
- A bit of a mess but all working
I went with the Armortek recommended battery,but you get this with the XT connector supplied if you search therefore no need for the Deans to XT adapter
At the moment the recommended battery is subject to a discount voucher on Amazon UK ,so this may help someone who is looking for a good discounted battery
Donald
Re: Series 1 Number 11,Sound,Motor and light test
Posted: Sat Feb 03, 2024 4:42 pm
by mick whittingham
Hi Donald.
Good to see someone posting about the electronics on the Series 1.
I'm just starting out with the Taranis transmitter and taking things easy. I don't want to blow anything up lol.
I managed to get the receiver to bind to the transmitter but I've got no further than that. Looks like I just need to make the connections to the receiver and give it a whirl.
I won't start to build for a while yet as I'm still researching what vehicle to base my build on. I'm looking for something non military perhaps. If I can find something with plenty of reference photos I will be happy.
What are you basing your build on?
Best regards Mick
Posted: Sun Feb 04, 2024 5:14 am
by Andy Thompson
I’m basing mine on as it would have left the factory, detail correct. I did think about patination as per the original. May do that when the time comes.
Posted: Tue Mar 19, 2024 7:00 pm
by Bob Mitchell
Does anyone know if the yellow and blue wires from the motor can be disconnected from the rest of the electronics to make it easier to make up the gearbox connections etc? It looks like it should split about half way along the wire but don’t want to pull it apart if it’s not meant to! Do all the electronics go in the engine space?
Appreciate any help
Posted: Tue Mar 19, 2024 8:38 pm
by mick whittingham
Bob. Mine has blue spade terminals halfway down and I pulled them apart to remove the speed controller and make installation of the motor and gearbox easier.
Mick
Posted: Wed Mar 20, 2024 3:40 am
by Bob Mitchell
Thanks it worked! It will be easier to fit now!
Posted: Wed Mar 20, 2024 9:05 am
by Charles A Stewart
hi All
Bob the electrics do fit under the bonnet, but it is a bit of a squeeze what with the speaker too.
- The battery goes under the seating, not on the front bumper.
However it all survived a test run around the track.
Charles
