Famo help
yves mouton
Been liked: 592 times
Famo help
Post by yves mouton »
Hello,
I have a little problem to fix part nr CSO 607 to the frame.
Beacause i put first the motors into the frame ( i think everyone did this first ) i can not have access the the nuts to secure part CSO 607
So my question is, do i have to take out one motor or can i take a little cut into the frame to have easy access to fix the nuts?
The small cut will not weaken the frame i think?
Best regards Yves
Riny Koks
Has liked: 1010 times
Been liked: 97 times
Re: Famo help
Post by Riny Koks »
Hello Yves,
I don't have a Famo bit i personally would never cut into the frame.
It will always affect the strength.
Riny
2019 M3 Lee #25
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
Bailey Bridge + Extension
florian rudolf
Has liked: 294 times
Been liked: 640 times
Re: Famo help
Post by florian rudolf »
Hi Yves,
I think your position for this part is wrong.
In the hole I think are threads, so you turn the screws from outside in...
yves mouton
Re: Famo help
Hello,
Florian i got the part upside down, now i see it. But there is no thread in the holes i got , i could tap M4 in it
Best regards Yves
florian rudolf
Re: Famo help
Mybe AT forgot the thread in there?
I don't know yet whitch screw size should fix the part. M4 or M5. Maybe you can make it for M5 screws? -
Been liked: 3480 times
Re: Famo help
2 off M4x40 cap heads. They screw into the chassis rail of the Famo - CS0101
yves mouton
Re: Famo help
Thanks for the help,
Problem solved, i thought there have to be M4 nut on the other side because my holes hat no thread.
So with the help of the forum i tap M4 thread from the outside.
Best regards Yves
yves mouton
Re: Famo help
Hello,
There is a little space in the house driving, there are 2 bearings on the axeldrive.
My question is do you have to put a copper bush also on the outside of the drive house?
Or stay this open? There is no bush in the manuel.
Best regards Yves
florian rudolf
Re: Famo help
Hi Yves,
I think ists open, because the tight bearing inside it does'nt matter.
yves mouton
Re: Famo help
Thanks Florian,
Dashboard is working with led lights,
The frontwindow is working ( can open and close ) thanks for the pictures
Today i workt on the fenders, they are ok and i have no gaps between the fenders and the driving compartment
it was a little bit work the fix them correctly.
Pictures comming soon.
Best regards Yves
