Leopard 2 Prototype
- Been liked: 3334 times
Leopard 2 Prototype
Exciting day today - the order for the tracks have been placed ... that means production volumes are now fixed. If you have not reserved your kit, better hurry up as we will not be able to make more.
The track is the most convoluted we have made so far - it consists of 6 different parts with a total of 9 pieces making up one track.
- The track link
- 2 end connectors
- 1 central connector
- 1 track pin
- 2 rubber pads (vulcanised to the base plates)
- 2 pad base plates
The track links will be made from aluminium and the moulds will take 1-2 months to perfect - so we always need to get these on order pretty early in the production lifecycle.
In addition we have placed the order for the moulds for the rubber tyres since these also always take a while to make.
- The track link
- 2 end connectors
- 1 track pin
- 2 pad base plates
- Peter Quambusch
- Been liked: 980 times
Re: Leopard 2 Prototype
Plus 7 screws....
Lord, give me strength to change the things I am able to change.... and patience to endure the things I can not change A bunch of Tiger and Panther variants, Leo II, Famo, 222s, a few 88`s and smaler ones like Hetzer, Stug III, 251, etc.
- Chang
- Has liked: 15621 times
- Been liked: 412 times
2 track pins ...
- Fabian Bekkers
- Has liked: 190 times
- Been liked: 105 times
Production of the Leopard 2A4 has started.
As Peter correctly identified - this is the short axel from one of the return rollers.
- Fabian Bekkers
Completed assembly for the short return roller and housing - just missing the tyre. Prototype should be with us in 3-4 weeks.
- Fabian Bekkers
Some more images as we progress on the Leopard 2A4.
Samples of the tracks have arrived, The tracks are aluminium with steel and rubber inserts.
- Been liked: 45 times
Will the kit contain the 18 grousers which are used to replace the same number of rubber pads when travelling over icy ground. These are normally carried/stored on the bow of the tank when not in use?
David.
David.
- Fabian Bekkers
Yes it willDavid Merritt wrote: βTue Oct 17, 2023 2:02 pmWill the kit contain the 18 grousers which are used to replace the same number of rubber pads when travelling over icy ground. These are normally carried/stored on the bow of the tank when not in use?
David.
Roadwheels coming together nicely.
They are made from pressed and laser welded steel with an aluminium hub and hub cap and rubber tyres.
The assembly in the photographs (excluding the tracks) is 0.66 kg.
- Has liked: 2253 times
- Been liked: 7126 times
Looking very nice.
- Been liked: 1709 times
That hub detail is very nice, much better than Chieftain.
