24v Power Supply System Compatibility.
Malcolm.Plumb
Has liked: 380 times
Been liked: 875 times
Post by Malcolm.Plumb »
While I decide on my final battery configuration is it possible to power every thing up and bench test it used a regulated 24v power supply?
There is mention that the motors produce regenerative power. Issues?
Anyone using one?
2022 Panther G #15
Has liked: 1363 times
Been liked: 1556 times
Re: 24v Power Supply System Compatibility.
It should be possible but it would need to be quite a beefy.
Expect 15 to 20 amps with the tank raised and everything (motors, smoke, sound) running.
I've tested single motors, with the gearboxes removed, from a 30V 3A supply without issue, but I have to wind the voltage up slowly or the current limiting kicks in.
Has liked: 762 times
Been liked: 1738 times
Been there - done that using a cheap eBay 10A power supply.
viewtopic.php?p=66159#p66159
Malcolm.Plumb
Thanks Guys, I'll sort something out and give it a go.
2022 Panther G #15
