Panther Build 2022 68
Posted: Sat Mar 25, 2023 8:49 pm
by Steve Cope
Hi all
Started the build and the 1st question of many, hopefully you will not get fed up with more than likely many questions.
Page 1
Q1, The front Glacia plate bow machine gun, should this be glued flush with the rear of the ball mount, or flush with the front of the ball?
Q 2, Should all retaining screws be thread locked?
Thank you for any advice
Re: Panther Build 2022 68
Posted: Sat Mar 25, 2023 9:58 pm
by Brian Ostlind
Hi Steve I would push the machine gun into the ball until the thick part is inserted and leave it there.
Thread lock with blue is good I’ve had lots of screws come loose without it. That being said some areas are more critical than others so I don’t use it on every screw.
Posted: Sun Mar 26, 2023 4:11 pm
by Steve Cope
Hi Brian
Thank you for the information
Posted: Tue Mar 28, 2023 5:57 pm
by Steve Cope
Hi Brian, enjoying your YouTube channel, need you to do a full detailed Panther build not missing out on anything then I will not feel out of my depth :wink:
Posted: Tue Mar 28, 2023 6:08 pm
by Brian Ostlind
Thank Steve.
