Hetzer sprockets -Toast!
Posted: Fri Mar 10, 2023 11:01 pm
by DaveMacri
Well it finally happened, I was observing these sprocket teeth wearing down over the past 6 months driving in the sand and dirt here-today they fianally gave up the ghost! Need to replace with steel sprockets as the aluminum is a tad to thin, any ideas for source?
Re: Hetzer sprockets -Toast!
Posted: Fri Mar 10, 2023 11:04 pm
by Brian Ostlind
Yeah, but it will cost you…
Posted: Sat Mar 11, 2023 2:21 pm
by Gerhard Michel
I would prefer aluminium, nevertheless. It's better to loose cheap sprocket rings than a complete set of track links. These rings you can order at a water jet cutting manufacturer according to your demand and complete it with drilled holes and so on. I made this at my King Tiger and my Hunting Tiger.
Here 2 types of water jet cutted rings at reworking on lathe:
And here a completed water jet cutted sprocket ring mounted (all parts used on non-Armortek models):
Posted: Wed Mar 15, 2023 12:32 am
by DaveMacri
hmmm
Posted: Sun Mar 19, 2023 4:15 pm
by DaveMacri
Better pics of deterioration level of the teeth with just about 2 hours total of run time in prairie grass and sandy surface.
Posted: Sun Mar 19, 2023 7:12 pm
by Jerry Carducci
I've used a laser /water jet machining outfit here, actually down in sili valley. They're quick, reasonable and J Littlefield used the same outfit
to cut sprocket rings for his 1:1 scale models..
PM if you want their info. They do prefer working off of at least a good drawing with dimensions with a CAD file being a best bet.
Posted: Sun Mar 19, 2023 9:04 pm
by DaveMacri
Thanx for the intel, Liam Mahoney is planning on doing steel sprockets and tracks for his Hetzer after looking at his kit since this occurrence. I will be getting a set from him...
Posted: Sun Apr 09, 2023 1:58 pm
by Roy Maynard
I’m currently building a Hetzer and would be interested in purchasing the steel replacements. Is there contact information available?
Roy
Minnesota USA
Posted: Sun Apr 09, 2023 7:07 pm
by Chang
Roy
Minnesota USA
Hi Roy,
Liam Mahoney's email : liam@lsm.net.au
Good luck.
Posted: Fri Apr 21, 2023 6:00 pm
by DaveMacri
Update on the steel sprocket rings, received replacements from Liam Mahoney and tested them out on the tank, they run perfectly now with no signs of wear on either the track links or the sprocket teeth. I have about an hour in on the test time in sand terrain...
Posted: Fri Apr 21, 2023 6:04 pm
by Brian Ostlind
Woohoo I need some too!
Posted: Sat Apr 22, 2023 2:30 pm
by Kees van Rijswijk
Hi,
count me in for a set.
kind regards Kees
Posted: Wed Oct 02, 2024 6:27 pm
by Roy Maynard
Are steel sprockets still available from Liam?
Please email me at roydefiant@aol.com
Roy Maynard
Posted: Wed Oct 02, 2024 11:05 pm
by Liam Mahoney
Hi Roy
Yes still available, email sent.
Thanks Liam
