hi, i have a hafco hm-47 mill/drill that suddenly wont start. i was working a part fine then stopped to adjust position of piece but mill would not start. i cant find any references so i'm asking here if by chance someone will know.
thanks
ray
Mill machine fuse location
- Has liked: 980 times
- Been liked: 94 times
Re: Mill machine fuse location
Im not familiar with this type of machinery but a regular cause could be the safety cover not closed.
I doubt the machine have a fuse of its own.
Good luck finding the problem.
Riny
Riny
2019 M3 Lee #25
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
Bailey Bridge + Extension
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
- Has liked: 2487 times
- Been liked: 443 times
You have a few options
1, is the emergency stop button pressed down or activated
2, On the rear of the control box there is a black plastic cover this houses the fuse
3, open up the control box there may be a fuse on the main board
- Has liked: 26 times
- Been liked: 103 times
hi guys,
i checked emergency stop & safety switch, both are ok.
i'll keep looking.
thanks
ray
i'll keep looking.
thanks
ray
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1014 times
Is there thermal protection on the motor? More basic question is there any possibility of a fault on the supply line the machine is using?
power is getting through. i was milling just fine, no problems, switch it off to adjust the x&y position and then pressed start..........and nothing.
weird.
ray
weird.
ray
- Has liked: 1341 times
- Been liked: 1538 times
No warning lights anywhere ? Could be as simple as a faulty start button.
- Tim Page
- Has liked: 40 times
- Been liked: 425 times
Sounds a lot like the problems Rivet has had with his over the years with dead motors.
went to the garage to try something with the mill and when i turned it on and pressed start, it worked. it's got me buggered what happened and why after leaving it a few days it works again. machinery huh.
thanks for your suggestions.
ray
ray
