M2.5 Castellated nuts
Malcolm.Plumb
Has liked: 462 times
Been liked: 953 times
Post by Malcolm.Plumb »
Hi
Anyone know of a source of some M2.5 Castellated nuts?
Looking at getting hold of some prior to starting my Panther G build.
2022 Panther G #15
Markus Beer
Been liked: 55 times
Re: M2.5 Castellated nuts
Post by Markus Beer »
Hello Malcom
try it once here:
https://knupfer.info/shop/index.php/mut ... ad-14.html
best regards
Markus
Jerry Carducci
Has liked: 3 times
Been liked: 1123 times
Post by Jerry Carducci »
Malcolm.Plumb
Many thanks.
2022 Panther G #15
graham pipe
Has liked: 51 times
Been liked: 218 times
Post by graham pipe »
Hi Malcolm,
Are you looking for M2.5 castle nuts for the roadwheels? If so, the real vehicle used M14 bolts and nyloc washers on the the outer face. But the nylocs are not the modern standard pattern - they are taller by about 3 mm and Type P as opposed to modern Type T. I know this 'cos I restored all 32 wheels of the Weald Foundation Jagpanther and also supplied all the wheel and sprocket nuts for the ex-Jacques Littlefield Panther which now resides in The Collins Foundation Collection in the US.
To find M2.5 nyloc nuts of the correct height might be difficult, My advice would be to use the excellent dummy studs as supplied by Armortek. They work fine on my Jagdpanther - not sure how they would work on the new steel wheel Panther G though.
Attached are some shots of the wheel restoration back in 2004.
All the best from Normandy.
The finished items ready to roll
A real wheel taken from a knocked out Das Reich Panther A in July 44 in our local town. The glacis is for my JP
First batch ready for delivery
Primed and ready for paint
Gas cutting was necessary on many bolts. Note the pressed steel bolt head retainers which prevent rotation.
Fun getting them apart...
Over 50 wheels were needed to make 32 good ones
Malcolm.Plumb
Hi Graham
Yes, that was what I was planning for the road wheels.
Do the drive sprockets use them?
2022 Panther G #15
graham pipe
Has liked: 51 times
Hi Dave,
Yes, the sprockets use castle nuts and split pins. From memory, I think they were M16 which in scale is 'twixt M2.5 and M3.
Here's what they look like in the flesh.
Malcolm.Plumb
Ok thanks, maybe need some for these then.
2022 Panther G #15
