Captured UC
Brian Ostlind
Has liked: 971 times
Been liked: 2066 times
Captured UC
Post by Brian Ostlind »
Planning on building mine as a captured and repainted model.
Has liked: 2267 times
Been liked: 7152 times
Re: Captured UC
Should be interesting Brian.
Dave Green
Has liked: 87 times
Been liked: 62 times
Re: Captured UC
Post by Dave Green »
Came across this relating to captured carriers
During the Campaign in north Africa the parties used each other Equipment that was left in the battle fields . In the pix is a German booklet explains how to use A Bren carrier and a radio. Printed in Berlin 1/3/41
Re: Captured UC
That's an amazing document David.
Brian Ostlind
Re: Captured UC
I am pleased to have had some extra help getting some work done. No shortage of elves here with my fourth coming in the next 30 days.
Brian Ostlind
Re: Captured UC
Got the drive all put together.
Brian Ostlind
Re: Captured UC
Brian Ostlind
Re: Captured UC
Today I bench tested the electronics and found out my JR radio works with Armortek components.
I tested the motors and the sprocket brakes and everything is working well.
Brian Ostlind
Re: Captured UC
Today I installed one track as well as the central servo.
Brian Ostlind
Re: Captured UC
second track
Brian Ostlind
Re: Captured UC
Eureka! I got the carrier running almost perfect (still might need to tighten the tracks)
Earlier I had put it together and test drove it but I couldn’t get it to turn. I tore down the axle and discovered I put the brake discs in backward. I had assumed the screw heads on the brakes were supposed to drag on the inside of the drum but I didn’t check the instructions close enough it’s clearly shown that the disc screw heads face in TOWARD the brake shoe. This configuration catches the brakes quite violently and definitely turns the whole carrier on a dime.
Here is a long video putting the carrier back together and the first successful test drive.
Has liked: 127 times
Been liked: 758 times
Re: Captured UC
Cool model - nice work!
Brian Ostlind
Re: Captured UC
Online
Been liked: 1781 times
Re: Captured UC
Love the vids, first time I've seen the rear axle internals exposed in a clip.
I'm not a fan of the "jaming peg type" control, liked the idea Phil developed with the pads, but milling is required and I still think there's mileage in the possibility of removing the pegs and fitting a friction to the disk. You've proved to me there's space to fit a friction disk and apparently slitting disks could be trimmed to act as the friction plate. (Punching out the center hole) I'm not sure what or if the original brake pad material pad would need to change. But may need experimentation but at least you don't need to strip the axle down to replace the pads
Keep the vids coming and ideas will flow. 8)
Brian Ostlind
Re: Captured UC
the rear bogies were bottomed out so I added preload spacers to the inner springs of the rear bogies to lift the rear end up a couple of millimeters.
