Lithium 12.8V 9Ah Battery Charger
- Has liked: 26 times
- Been liked: 193 times
Advice please, could someone recommend a charger for my Lithium 12.8v 9Ah 115.2Wh LifePO4 batteries.
- Gerhard Michel
- Has liked: 3 times
- Been liked: 691 times
Re: Lithium 12.8V 9Ah Battery Charger
Hi Graham,
for a charger recommendation it's very important whether your LiFes have a BMS or not. With BMS you only need a simple AGM charger, without BMS you need a balancing charger.
Gerhard
Gerhard
Thank you Gerhard, my battery does has BMS as specified in the data sheet so I can follow your advice on which charger to buy. I assume as with many things quality matters.
- Gerhard Michel
Hi Graham,
I would choose an automatic charger which stops charging when the final charging voltage is reached. Charging current (maximum) should refer to the battery data.
Gerhard
Gerhard
