Suggestions for a good 24v charger
Posted: Thu Jun 30, 2022 8:45 am
by Peter Silcock
The old mainstay of 24v lead acid/agm battery chargers, the Accumate Pro seems to be long gone and probably outdated now. Can anyone suggest a modern multi stage 24v charger as an alternative for a new Armortek owner?
Re: Suggestions for a good 24v charger
Posted: Thu Jun 30, 2022 11:10 am
I use two CTEK 5A chargers for my SLA batteries.
If you want to stick to a 24V charger, they do one, which I believe is what Mark used to use to charge the factory models.
Check the current output though, as some SLA batteries don't like too high a charging current.
The Yuasa REC22 batteries I have bought recently have a maximum charging current of 5.5 amps.
Posted: Thu Jun 30, 2022 11:30 am
by Vince Cutajar
Posted: Thu Jun 30, 2022 12:58 pm
by Peter Silcock
Thanks Adrian and Vince for the replies. Forgot about CTEK and I use them on my cars as battery maintainers as well! An age thing...
Posted: Thu Jun 30, 2022 5:21 pm
by yves mouton
Hello,
I also use a c-tek MXT 4000 24 volt
Best regards Yves
Posted: Fri Jul 01, 2022 8:32 am
by Peter Silcock
Thanks Yves - will take a look at that one too.
