Making the windscreen with simple basic materials
Posted: Thu Oct 09, 2008 7:14 pm
Like me I bet several owners searched through all the boxes looking for
componants to build the windscreen, and all we found was the steel frame
on its own.
At least one modeler has made a more realistic looking windscreen
To save money I used the exsisting windscreen and troted off to the
nearest glass works and they kindly cut me three pieces of 4mm float glass
making them slightly smaller than the actual size of the openings to allow space to fit the brass frame which I bought from the local model shop.
The glass was a £1 and the brass was five strips less than a fiver.
I measured the brass strips fairly accurately so they fitted snugly around
the glass. To achieve a tight fit within the frame I used thin slivers of
wood left over from another model and placed these between the glass and frame. No glue used.
Excuse the colour as flash is kaput!
And another
So for a couple of quid the screen starts to look like one
Heres a view mounted temp in positon
And............
Next job is to clean it up and add dummy wipers and motors.
Regards Stewart
PS Someone with more talent than I and more betterer tools can make the
window open
on its own.
And another
And............
Regards Stewart
window open
