Its help an RC muppet time again
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Hi All,
Having got my Carrier back from Steve I am in the process of adding everything back in again. It drives very smoothly on the twin motor setup but for the life of me I cannot get the sounds to work. Has anyone with a twin motor drive used the standard sound setup and if so do I need to modify anything to get it working. I get the required two beeps etc. when I power on and have channel 5 set to the 3 position switch on the Flysky FS 16. I must be missing something but can't see what.
Dave
PS Steve, you don't have 3/4" section of the top bumper laying round thats missing :-)
www.armorpax.net
Has liked: 1479 times
Been liked: 1683 times
Re: Its help an RC muppet time again
Have you need through the teaching process with the button on the Benedini ?
Hi Adrian,
Checked all the connections etc as per the AT instructions, get the prescribed beeps but can't get the initial sound to trigger for the setup process?
Did wonder if it is something to do with two speed controllers instead of brakes and whether I need to do something with the cable setup?
Dave
www.armorpax.net
I have sounds again thanks to Mr. Harris :-) Now just need to figure how I can get both speed controllers to rev the engine rather than just one. Any advice anyone?
Dave
www.armorpax.net
You should have said on the phone :D
You need a connection from the receiver to both the PROP1 and PROP2 inputs on the sound board, so that moving either side will rev the engines.
The easiest way to do it is to use two splitters. The single leg goes into the receiver. One leg of each goes to the speed controller and the other goes to the sound card.
Thanks Adrian, now why didn't I ask that earlier...………:-)
www.armorpax.net
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Post by Dennis Jones »
Hopefully the board is programmed for gas on both channels.
Hi Dennis,
did it work on yours?
Dave
www.armorpax.net
Dennis Jones
Has liked: 10 times
I don't use a Benedini board, so I re-programmed the board I use anyway (it's a lookalike). Did it work ok on yours Dave ? If not I can re-program your board possibly at Tankfest if needed.
