Tiger Lift
Brian Leighton
Tiger Lift
Post by Brian Leighton »
Quick question, what are folk using to sit their Tiger on during the build? I'm struggling moving my tank on and off my Black and Decker work mate.
Gary Richardson
Has liked: 755 times
Been liked: 1772 times
Re: Tiger Lift
Post by Gary Richardson »
Hi Brian
I use a 200kg scissor lift trolley, easy to move about and you can raise and lower it depending which part of the Tiger you are working on.
If you also use a motorcycle lift on top of the trolley you will be able to raise the tracks off the lift table when testing the drive/tracks and be able to rotate the tank to get easy access to both sides.
You can get more info from the knowledge base link below.
viewtopic.php?f=34&t=5798
Gary
GlenStenhouse
Has liked: 17 times
Been liked: 26 times
Re: Tiger Lift
Post by GlenStenhouse »
The coffee table in the lounge. :?
One of the perks of being single I guess.
Gerhard Michel
Has liked: 3 times
Been liked: 650 times
Re: Tiger Lift
Post by Gerhard Michel »
I use a lifting carriage to transport the tanks between storage area (old tables), the working desk and the ramp to drive it out through the basement window.
At first I used a self made crane and a small and long ramp, but this was rather inconvenient and some dangerous.
Gerhard
