Lee
Do you know how to wire up the blank firer? I want to make sure I understand before I try to wirer the relay.I think there are 4 wires?
2 from the power loom red & black and 2 from the 8 way conector.
Which on mine is blue.they all go to one side of a relay.from the electrical
schematic one blue and the black are together as one.and go into NO.And the blue on the outside of the 8 way conector goed into the RL A.And last the red goes into the NC.
So is this corect? Thanks Lee from Dan
blank firer how to wire
- Been liked: 15 times
Hello Dan
The magizine will only go one way is the motor turning it in that direction??
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Hi Lee
No the motor is turning wrong direction.If I change how the relay is wired,
will that change how the motor turns?
Now I have the blue & black into [NO]
blue into [ RL A] & red into [NC]
and blue n black should go to yellow wire.[-]
blue goes to white wire [+] I assume orange is +
I don't know much about this system.
Dan
Dan
Hello Dan
Just swap the black and blue arround. That should do it.As per wireing diagram.
Lee
Lee
Hi Lee
thanks I tryed that but that did not work.I also tryed other ways 4 total.
only 1 thing I did not try is.putting the blue/white wire into NO
this white is on the outside of the 8-way conector.
with the yellow wire next to it.
I asked Mark to answer me every thing I tryed did not work.
I don't understand the system. like where the power {+,-} should be
{NC,NO,RL} and the two blue wires.
blue/white and blue/yellow .
Thanks for your help. Dan
