Hi I have just installed a Benedini sound unit with a Sabretooth dual 2 x 32Amp speed controller set to mixing mode on the dip switches such that I can drive from one stick. I can only get the proportional sound to work off the one channel? Any ideas anyone?
Thanks,
Benedini sound unit with eleven mixing
- Has liked: 4 times
- Been liked: 245 times
- Has liked: 1341 times
- Been liked: 1538 times
Re: Benedini sound unit with eleven mixing
When you went through the sound teaching process, did you just move the stick up and down or diagonally ?
Up and down wouldn't produce any output on the steering channel, so the Benedini will ignore it.
- Has liked: 269 times
- Been liked: 324 times
Is not the problem here that the channel from the receiver is going to the sound unit before any mixing occurs ?
Is the transmitter capable of doing elevon mixing ? If so, maybe best to do it there rather than at the ESC ?
Having played around with this all evening I think that the prop 2 channel is not formatted for a second sound channel. You can use it as a sound selection Chanel as well as the prop 3 channel. Any idea how/if you can reconfigure it?
Thomas's TBS Flash software and a serial lead. PM me if you need a lead
