No 82
Posted: Tue Sep 07, 2021 2:49 pm
by Mark Alcock
Hi all
I'm new here but have been building models of various scales for over 40 years. Looking forward to getting on and building No82, going to base it loosely on a vehicle from the 7th Armoured Division called 'puddle jumper' armed with a .50 cal during the Normandy campaign. I won't bore you with the general build but will post anything that's worthy of your interest.
Mark.
Re: No 82
Posted: Tue Sep 07, 2021 3:18 pm
Welcome Mark.
First time I heard the name Puddle Jumper was on Stargate Atlantis :-)
Re: No 82
Posted: Tue Sep 07, 2021 9:00 pm
by John Clarke
Welcome Mark
I don't think there's any such thing as a boring general build in my book, purging your model with pictures and descriptions is always asset to those who will follow. And maybe looking back on the build you'll find a completeness of the journey.
Experience of the forum usually shows that each one of us builds the models in different ways. Some will go mega, some will go subtle.
A cross section of the UC builds shows the diversity in the final stages and massive changes to the final drive systems.
Anyway, if you do a good job in pictures, it saves me trying to make head or tail of the instructions when I get round to building mine 8)
(Sod the journey, lets hit the bar and the pool!) :lol:
Re: No 82
Posted: Sat Sep 11, 2021 9:45 pm
by Mark Alcock
Had a couple of hours on 82 today, built up the suspension bogies and and tried the hull plates for fitment, all good this is a very well engineered kit. Have an idea of using an 80 amp RC crawler ESC in the carrier which I will be able to program and set up to suit the carriers characteristics.
Re: No 82
Posted: Sun Sep 12, 2021 9:27 am
by Björn Johansson
Hi Mark
I´m also a newbie here , but ecco John there´s always somehting to learn from all people here.
Welcome
Re: No 82
Posted: Sun Sep 12, 2021 5:27 pm
by Mark Alcock
Forgot to mention yesterday that the sleeves on the main suspension units are a little to big for the springs to go over as has been mentioned in other threads. Having no lathe I decided to improvise and used my battery drill. The middle sleeve will go into the drill chuck and can be turned down with a needle file on both sides. The rounded sleeves on the end of the springs won't sit in the drill chuck so I used one of the middle sleeves and using a 3mm nut and bolt bolted the rounded sleeve to it so it could be held in the drill chuck and turned down accordingly.
Re: No 82
Posted: Sun Sep 12, 2021 6:45 pm
by John Clarke
Nice,
The portable lathe made by Im-pro. Got two myself 240vac and a 14vdc for the small stuff 8)
Re: No 82
Posted: Sat Sep 18, 2021 2:44 pm
by Mark Alcock
At bit more progress, managed to get most of the model into a coat of etch primer yesterday and today started to put a bit of green on. Used Halfords etch primer and using Tamiya flat olive green with my airbrush.
Re: No 82
Posted: Mon Sep 27, 2021 8:34 pm
by Mark Alcock
Evening all.
Not much to report this week due to time restraints but I did manage to pin the tracks together.
A question for those UC owners who have purchased the motion pack what do you get in the pack?
I assume motor and gearbox, ESC, Differential, brakes etc anything else?
Mark.
Re: No 82
Posted: Tue Sep 28, 2021 11:45 am
by Dennis Jones
Hi Mark,
Motor & gear box, differential, brake assemblies, 3 servos, esc and wiring harness.
Dennis.
Re: No 82
Posted: Sun Oct 17, 2021 3:21 pm
by Mark Alcock
A little more progress with suspension and tracks test fitted. Tracks are a little slack even with the adjusters at full stretch so I'll look to take a couple of links out during final assembly.
track 3.jpg (26.23 KiB) Viewed 6549 times
track 4.jpg (26.82 KiB) Viewed 6549 times
Re: No 82
Posted: Mon Oct 18, 2021 11:42 am
by Dennis Jones
Hi Mark,
I ended up with 154 links, 10 less than was in the manual.
Dennis
Re: No 82
Posted: Tue Oct 19, 2021 3:35 pm
by Mark Alcock
Hi Mark,
Dennis
Hi Dennis.
The tracks have 162 links at present so I reckon they may well end up in the 150's.
Mark.
Re: No 82
Posted: Mon Dec 27, 2021 12:34 pm
by Mark Alcock
Hi all.
Hope you all had a good Christmas.
Not done much to the carrier for a while so I'm hoping to a do bit this week while I'm on holiday. My motion pack arrived earlier this month and I'm going to install it as is except I'm going to replace the ESC for a Hobbywing quicrun 1080 unit which you can program various settings in the ESC which will give the model an adjustable more controlled power up take and drag braking function. You can also set how much power you want in each direction so to simulate reverse gear I'd use probably 25% power when going backwards rather having to control it on the transmitter. I'll let you know how it goes.
