Easy 8 - BobM
- Has liked: 127 times
- Been liked: 621 times
- Has liked: 681 times
- Been liked: 268 times
Re: Easy 8 - BobM
Yes, you sure are a pathfinder, Bob!Oliver Brüninghaus wrote: ↑Sat Jun 11, 2022 1:12 pmHello Bob
really impressive build with all the finesse and most modern technologies up to 3-D printing from metal.
It is always a pleasure to watch the model evolve.
Oliver
- Has liked: 103 times
- Been liked: 701 times
Re: Easy 8 - BobM
A few of the latest shots of E8. Finally got the removable top and rear deck mounting done. Both rear and front decking are removable for access to internal components. Held in place by friction and brass lugs. The lugs hold the deck firmly in place at exactly the right height.
Next up main motor test.
Hull deck mounting
Overall shots outside in the sun.
Thanks for looking, till next time...
Hull deck mounting
- mark j. radick
- Has liked: 393 times
- Been liked: 538 times
- Been liked: 1574 times
- Has liked: 21 times
- Been liked: 737 times
Re: Easy 8 - BobM
Another great model in the making Bob, I see a set of weights on the ground, are you in training so you can move your tanks
Regards Jeff
Regards Jeff
Re: Easy 8 - BobM
Mark, David, Simon, Jeff, thanks for the feedback. Jeff I let the 1000 lb lift table do the heavy lifting of the AT tanks. The barbells are just for decoration - to give the illusion of fitness. LOL. I'm either getting older or these models are getting heavier.
Best regards all,
Best regards all,
- Has liked: 224 times
- Been liked: 181 times
Re: Easy 8 - BobM
GREAT JOB Bob!!! Keep posting pics!!
- Has liked: 562 times
- Been liked: 409 times
Re: Easy 8 - BobM
Great work as always Bob, and very interesting to the Sherman fans, regards simon .
- Been liked: 350 times
Re: Easy 8 - BobM Dale
Hi Bob just got back home from two weeks away having trouble PM you So I'll try this Dale
Re: Easy 8 - BobM
Few more bits added to E8 backside. Got the steel hitch finished and mounted. Also rear tow hook mounted. Calling it nearly done on the bottom detail bits..
Hooks as printed, 17-4 Stainless:
Hitch assembled. 17-4 SS and brass:
Fully functional:
Painted and detail safety chain added:
Mounting points to hull:
Hook and mount point:
Installed onto hull:
Till next update, best regards all, Bob
Fully functional:
