Recoil issues
Derek Attree
Has liked: 219 times
Been liked: 200 times
Recoil issues
Post by Derek Attree »
Hi Elefant builders.
I am getting near to being finished with my conversion to a Ferdinand but I am
having issues with the recoil spring not pulling the main gun back to the cut out in the cam
despite shortening it 30mm :(
There is no paint on the barrel where it goes through the bushes and it seems a nice sliding fit does
anyone else have ideas or did anyone else have this issue. ?
Still playing around with things on that.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: Recoil issues
Post by Steve Norris »
Hi Derek,
I have recently installed the recoil in my Elefant and everything worked perfectly after a little bit of messing around withe the 2 switches. The only thing extra I did was to add a rubber stop to stop the slide smashing into the end of its slot on full recoil.
Not the best photo but it may help.
I am away from home for the next week, if you are still stuck when I get back I can post some better photos.
Derek Attree
Re: Recoil issues
Hi Steve
Thanks for the input my problem is the spring does not pull the barrel back
when the cam rotates round to the square cut out .
I remember the RC sparks guys saying they shortened the spring for the same reason
I will carry on and shorten it some more unless Kian or Chris have some answers or solutions.
Has liked: 1495 times
Been liked: 1699 times
Re: Recoil issues
Any chance you can video what's happening ?
Derek Attree
Re: Recoil issues
Hi Adrian
Not at the moment as I have it all in bits again :roll:
Derek Attree
Re: Recoil issues
Hi All
Chris has been in touch with some ideas I will play with these over the next week
or so and let you know.
Derek Attree
Re: Recoil issues
Hi Guys
So a small update to close this down after an email from Chris I stripped it down
and found 3 small machining ridges on the parallel section of the barrel that goes through the bushes
on the ball mount and these were causing drag.
A couple of minutes in the lathe with a bit of fine emmery cloth to polish those out and
then I put the ball mount in the lathe and polished the inside of the plastic bushes to remove some slight turning
marks in those.
Now it is as smmoth as silk. :D
Thanks again for the input
