Jagdtiger No.41 in Germany
- Sascha Hornbach
- Has liked: 399 times
- Been liked: 473 times
Re: Jagdtiger No.41 in Germany
Autumn is Jagdtiger time
I do a few weldlines and also started to make the castingsurface on the drive wheel.
regards
Sascha
regards
Sascha
- Been liked: 350 times
- Sascha Hornbach
Thanks Dale!
I started to build the electronics. The board is from 8mm PVC. I also made the Airtank mounts from PVC.
Airtank
Engines
Batteries right side
Main Switch, Relais and Controller (switch)
Hatch closed, Mainswitch reachable through the Hatch.
100A Fuse
regards
Sascha
Airtank
Engines
100A Fuse
regards
Sascha
- Sascha Hornbach
Hi Folks,
I finished the travellock A-Frame with some weldings. I also worked on the drivers hatch and noticed some differences with the original. So I made some CAD work to compare the measures and shapes from the original blueprints and images of 331 in the states. I decited to rebuild the complete frontplate with the gearplate and the two hatches. Next step is to build the bolts and some other details. More to come....
regards
Sascha
regards
Sascha
- Sascha Hornbach
Last days I build all the boltscrew imitations from brass. The hatches get angled edges, lifting hooks and the hatchstopper are also done. I rebuild the drivers scopeholder from original blueprints. Next step is the turning part of the scopeholder and the cover above it.
regards
Sascha
regards
Sascha
- Sascha Hornbach
Few Details completed, the hatches are nearly ready. I added the Handle, the Castlenuts of the Hatch and reshaped the little Dome over the swing axle.
The parts of the cleaning rod holder are finished and today I milled some parts of the ropeholders.
I also recieved some great parts made by John Fitzsimons.
- Sascha Hornbach
Last Weekend I do some brasswork. I rebuild the front Mudguards for more scale-look. Unbelivable how much parts and work only such a single Mudguard is. I also think at the production line in wartime, what a waste of time and energy to produce such a complicate part that mostly fast ragged down in action.
best regards
Sascha
best regards
Sascha
- Sascha Hornbach
I finished the C-Shackles in Aluminium.
Secure mechanism open
And in its natural habitat
- Sascha Hornbach
I finished some small details last days. Very timeconsuming but not much to see.
Mountings for the 20t jack
Ropemountings and Sleeve for the crowbar
Sascha
Sascha
- Sascha Hornbach
Hi all,
I finally installed the Battery and started wiring. In the left: Relais to switch the Mainsystem on/off, above the MiniMKS Multiswitch and the Jeti Reciever, above is the fuse and 2 voltage Transformer (6V to Reciever and 12V to Soundmudule). On the right side is the charging switch, the main battery cut off switch and the 26V dividerpins.
And a small Video from first Jagdtiger steps outside
regards
Sascha
regards
Sascha
- Sascha Hornbach
Wiring is almost complete, all systems work fine. I also installed the Compressor and the valve including the pressure pipes. A Video of the Gun recoil is following soon.
Sascha
Sascha
- Has liked: 1434 times
- Been liked: 84 times
Sascha
Nice Jagdtiger. Love the internal system work.
Everyone, if you have not been to Sascha's Submarine Website you NEED to take a few minutes and visit it.
https://pressluftjunkies.de/
I also enjoy German subs. Over the last 70 years I've had the pleasure of visiting the U-505 in Chicago around 5 times. Have several sub kits being built and several still boxed waiting to go. Sorry, to say mine will only be able to dive once, then sit on the bottom.
Enjoy both worlds.
Enjoy the Builds
Later Tim
Enjoy both worlds.
Enjoy the Builds
Later Tim
Tampa Bay, Fla area USA.
- Sascha Hornbach
I added a few new Details. The Scherenfehrnrohr hatch is nearly ready, the sealing follows after paintwork. I also finished the Antennabase and the Antenna. Also the ropholders are finished. At least I made a red indicator light if the Battery is in charging mode.
regards
Sascha
regards
Sascha
- Sascha Hornbach
- Sascha Hornbach
My new Pages are online now, it was a lot of recherche work to do, especially researching the way of 331. But It is also a lot of work to do and not all articels are translated yet. If someone of you have any missing Information ( chassis numbers/tactical numbers...), feel free to contact me.
The next articel will be a "Now and Then" in Neustadt from the last days of 331 and the Time between 1945 and 2024.
Enjoy!
regards
Sascha
Enjoy!
regards
Sascha
