Brakes and drive.
Mike Keenan
Been liked: 2 times
Brakes and drive.
Post by Mike Keenan »
UC 22 Mike Keenan.
Well on with the build brakes and drive working first try nice and smooth,held the diff in the lathe and ran it this make all the difference to smooth operation no problem with brakes binding well pleased. Waiting for Daves tasty bits.
Bob Butts
Has liked: 12 times
Been liked: 7 times
Re: Brakes and drive.
Post by Bob Butts »
Hi Dave
Just putting my drive together but noticed that diagram says that the half shaft should be attached to the diff by a 10mm pin but the ones supplied ar 14mm.
Which size did you use?
Many thanks
Mick Regan
Has liked: 34 times
Been liked: 6 times
Post by Mick Regan »
Hi Bob
You should have 3 sizes of pins supplied, 2 off M3 x10 for the half shafts, 2 off M3 x 14 for the “dog bone” connecting rod from the motor to the diff, and 2 off M3 x 20 for the brake pads. If you are missing any of these, drop an email to Monique. She is very helpful👍
Hope this helps.
Mick.
