UC ER0123 and ER0124
Posted: Tue Feb 02, 2021 5:39 pm
by Bob Butts
Hi Guys
Another question from a newbie.
If you look at the attached photo you will see that I screwed down ER0125 and the girder bent because there is a gap between the girder and the plate.
Should I use a couple of washers/spaces and a bigger screw.
Many thanks
Re: UC ER0123 and ER0124
Posted: Tue Feb 02, 2021 7:26 pm
by Graham P Hough
Bob it may be worth easing off the larger part as they bolt together to see if something is out of line. I checked on mine and I don't have such a 'step' on mine. Always better to see if you can adjust the parts before you alter the instructions.
Posted: Thu Feb 04, 2021 8:43 pm
by Bob Butts
Many thanks for your wise advice Graham as I have managed to force it up a bit.
all the best
