How to avoid driving gear problems....
- Peter Quambusch
- Been liked: 1045 times
Problem: When driving in heavy terrain, a lot of pressure (torque) is exerted on the final drive. This leads to movement of the pin (key), which then mushrooms the drive axle. Due to this, the Taper Lock breaks. Happened twice with my King Tiger and once with my Elefant.
mushrooming leads to the breakage of the taper lock:
Last edited by Peter Quambusch on Tue Sep 29, 2020 2:55 pm, edited 2 times in total.
- Peter Quambusch
Re: How to avoid driving gear problems....
Solution: Washer and 5 x 10 cap screw to hold the pin in place:
Since installing, I never had the problem again.Lord, give me strength to change the things I am able to change.... and patience to endure the things I can not change
- Has liked: 297 times
- Been liked: 645 times
- Been liked: 1767 times
It's always best to drive the Bigger Tank's with care, as the real German Tank crews were instructed, the big Armortek tanks behave very much like the real thing, stresses and strains to be aware of while Driving, The lighter models, stug, panzer 111, panzer 1V, even the Panther, Jadgpanther are a bit more forgiving, but the heavy vehicles, Kingtiger, Jadgtiger, chieftain, centurion, Tiger, a bit more careful, regards simon manning.
- Gerhard Michel
- Has liked: 3 times
- Been liked: 690 times
Hello Peter!
Well, I think that a tank is a tank and must be able to be driven like a tank, also if being 1/6 scale: logging small trees up to 2 m of height, crushing hedges and so on. This may cause some smaller damages, which may be repaired. That's real live of a tank driver (also full scale)
Therefore I appreciate your solution making your drive train stronger to avoid that kind of damage.
Gerhard
Gerhard
- Has liked: 15 times
- Been liked: 70 times
Peter,
Very interested in this mod for my Jadgtiger.
I think I'm not understanding something, how does this actually keep the pin in place?
- Been liked: 741 times
Hello Don
The taper lock keep the pin on the drive axle, the taper lock is a cone chape and the inner side
of the sprocket is also a cone chape. You lock the taper lock in the sprocket by 2 grub screws.
To unlock the taper lock you screw out the 2 grub scews and there is a 3 hole there you put
1 of the grub srews in the hole and the taper lock comes out of the sprocket.
Best regards Yves
Best regards Yves
- Peter Quambusch
Hello Don,
The washer keeps the pin (key) in place. W/o the washer, it will start to move outwards.
Peter
- Peter Quambusch
Thanks for your advice, Simon! That´s exactly what I was looking for...simon_manning wrote: ↑Tue Sep 29, 2020 9:55 pmIt's always best to drive the Bigger Tank's with care, as the real German Tank crews were instructed, the big Armortek tanks behave very much like the real thing, stresses and strains to be aware of while Driving, The lighter models, stug, panzer 111, panzer 1V, even the Panther, Jadgpanther are a bit more forgiving, but the heavy vehicles, Kingtiger, Jadgtiger, chieftain, centurion, Tiger, a bit more careful, regards simon manning.
- Peter Quambusch
Hello Gerhard, I fully agree with you!!Gerhard Michel wrote: ↑Tue Sep 29, 2020 10:57 pmHello Peter!
Well, I think that a tank is a tank and must be able to be driven like a tank, also if being 1/6 scale: logging small trees up to 2 m of height, crushing hedges and so on. This may cause some smaller damages, which may be repaired. That's real live of a tank driver (also full scale)Therefore I appreciate your solution making your drive train stronger to avoid that kind of damage.
- Has liked: 749 times
- Been liked: 360 times
So, if the key has worked its way half way out, the excess load will start chewing on the shaft?
- Peter Quambusch
Jap, the further it moves out, the greater the mushrooming becomes.Christoffer Ahlfors wrote: ↑Wed Sep 30, 2020 8:11 pmSo, if the key has worked its way half way out, the excess load will start chewing on the shaft?![]()
Last edited by Peter Quambusch on Thu Oct 01, 2020 7:43 am, edited 1 time in total.
This explains it! Thank you Peter. Mod added to the list. One more question (I always have one more question): How do you then retain the sprocket hub cap?Peter Quambusch wrote: ↑Wed Sep 30, 2020 8:15 pmJap, the furthe it moves out, the greater the mushrooming becomes.Christoffer Ahlfors wrote: ↑Wed Sep 30, 2020 8:11 pmSo, if the key has worked its way half way out, the excess load will start chewing on the shaft?![]()
- Peter Quambusch
Hi Don,Don Gray wrote: ↑Thu Oct 01, 2020 3:41 amThis explains it! Thank you Peter. Mod added to the list. One more question (I always have one more question): How do you then retain the sprocket hub cap?Peter Quambusch wrote: ↑Wed Sep 30, 2020 8:15 pmJap, the furthe it moves out, the greater the mushrooming becomes.Christoffer Ahlfors wrote: ↑Wed Sep 30, 2020 8:11 pmSo, if the key has worked its way half way out, the excess load will start chewing on the shaft?![]()
Nice to hear from you again. How far is your JT project?
To answer your question, I use grease on the KT and Tigers hub caps, the Elefant´s are held in place by cone head screws. Panthers have not been coverted yet, but will let you know, once done. For the JT, I have something diffrerent in mind.... I have to test it first, to see if it works. If so, I will post it asap.
Peter
- Been liked: 1842 times
This might help fitting the taper locks correctly. Pop this into your web browser. It will also show you the correct torque settings for tightening up the grub screws. I should add if the key fills the key way head to toe there is a fair chance you could crack the taper lock when you tighten up.
Fenner Taper Lock Installationwww.fptgroup.com › dss › docs › 690_06_Fenner_Taper...PDF
