Gun balance and elevation control
Sam Hough
Has liked: 69 times
Been liked: 53 times
Post by Sam Hough »
Hi,
Was the Tiger 1 gun close to being neutrally balanced? Also was there any damping/springing?
I get the impression no power assist for elevation (like turret rotation has).
I'm sorry if should have been able to easily find the answer myself but I've had no luck so far...
Sam
Paul Wills
Has liked: 646 times
Been liked: 143 times
Re: Gun balance and elevation control
Post by Paul Wills »
Hi Sam,
The tiger 1 gun has a hydrophilic spring balance, it is placed on the turret wall for the early tiger.
Early Aust E Tiger 1 Canon Balance spring & MG34.jpg (70.42 KiB) Viewed 1989 times
Early Aust E Tiger 1 Canon Balance spring 01.jpg (53.62 KiB) Viewed 1989 times
Early Aust E Tiger 1 Canon Balance spring 02.jpg (33.04 KiB) Viewed 1989 times
Early Aust E Tiger 1 Canon Balance spring 03.jpg (41.21 KiB) Viewed 1989 times
and at the back of the turret basket in the later variants.
RM-5010 Tiger I Middle Production w Full Interior (3).png (412.41 KiB) Viewed 1989 times
I've been working on a representation of it for my early tiger, but haven't finished it yet.
Both turret turn and elevation were power assisted and were controlled by the gunner via his pedals on the floor of the turret basket and the traverse wheel, but this could also be done manually if there was a loss of power. The commander also had a manual override.
Paul
Sam Hough
Has liked: 69 times
Post by Sam Hough »
Thanks so much Paul,
It didn't seem very likely the breech was heavy enough to counter the length + mass of the barrel but I couldn't see what was countering it.
So was all the force to move the gun up and down through this http://tiger1.info/EN/Elevation-gears.html gear segment? Presumably with a radius equal to its difference from the pivot in the mantlet?
The Haynes book, shamefully my only non-online reference, says there was fine adjustment. Is that what the http://tiger1.info/EN/Elevation-wheel.html is for? That power assisted too?
tiger1.info is an amazing resource but I really struggle to find my way around.
Sam
Paul Wills
Hi Sam,
Yes that is the gear, however, the counter balance is a little more complicated, this is the first type in the early tiger.
Your second link is the manual elevation wheel which is fixed to the beam that is attached to the elevation gear box in an early tiger.
All the info you need is on Davids site but to navigate the information you need to understand that he has broken everything down into the components.
Another book to look out for is (the research squad tiger).
Paul. :wink:
Sam Hough
Has liked: 69 times
Post by Sam Hough »
Thanks Paul!
After re-reading the section in the Haynes book about the gunner's food pedals I'm also now going down the rabbit hole of what the MG retract was for!
https://www.amazon.co.uk/Tiger-Modern-S ... 0955642213 added to be Christmas list!
Sam
Paul Wills
Hi Sam,
Amazon don't have it in stock but If you want the research squad book, you can get it here http://www.theresearchsquad.com/index.p ... tiger-712/ and click on the on sale here. they seem to have their own distributors, £29.99.
I'm not sure what your question is on the MG retract?
Paul. :wink:
Sam Hough
Has liked: 69 times
Post by Sam Hough »
Thanks Paul,
I've sent the link to my wife with a really subtle hint about christmas ;)
Re: MG retract. Why would they need that and any idea how much if would move by?
Sam
Paul Wills
Hi Sam,
I am not really sure, if Kent was still on here he would know. I have seen it written down somewhere but I cannot find the exact measurement that it moved by, I think it was 7mm horizontal and 14mm vertical, but I am not sure. The only reason I would think it would need to be adjusted would be for the firing arc, closer or further away.
Paul. :wink:
Sam Hough
Has liked: 69 times
Post by Sam Hough »
Many thanks Paul,
I'm still digesting the photos you sent and the book is on order. Really should get back to putting the tank in working order before worrying about future upgrades.
Sam
