electric problem with steering unit / servo
Posted: Thu Feb 27, 2020 9:32 am
by florian rudolf
Hi all,
I have a problem with my steering Servo in the Famo. May anyone is having a solution.
So the Famo is working well an steering is perfekt if the sound is off.
If I switch the sound on, the steering Servo is doing his own thing, not like a signal problem, its like someone else is steering.
The base:
I use the Benedini TBS mini V2 with an Benedini amplifier and two speakers visaton 10mh.
the Servo is working with the receiver power suply (an 5A converter from the 24V accu). - I attemped it to drive the servo with an external accu. - the same problem.
What can the problem be? - I think its not a disorder from the controler. Its a 2,4ghz.
its like a system mistake between the Servo an the Sound module?!
Florian
Re: electric problem with steering unit / servo
Posted: Thu Feb 27, 2020 10:31 am
by Mick Regan
Hi Florian
I don’t know what the rating of your steering servo is, put I’m assuming it’s high torque. You could be at the limit of your 5a converter, which will cause the voltage to drop, and cause the symptoms you are reporting. If you have a voltmeter, you could monitor the converter output with everything running and look for a voltage drop.
Is the converter a reputable make, or a cheap Chinese version. A lot of the cheaper ones do not maintain there output voltage where they are close to there maximum rating.
Hope this helps.
Mick
Posted: Thu Feb 27, 2020 2:48 pm
by Gerhard Michel
Hi Florian,
I suppose that is an interference problem. Probably Benedini uses a class D amplifier which produces some electrical interferences to the servo. Try a ferrite ring together with the servo cable. The DC-DC-converter is out of suspicion if an seperate akku for the servo shows the same result.
Posted: Fri Feb 28, 2020 1:18 pm
by Peter Silcock
Thomas also does an audio isolator circuit which worked for me.
Posted: Fri Feb 28, 2020 4:19 pm
by Mark Heaps
If trying the ferrite ring solution, please note slipping the cable just through it will not help. You need to feed the cable through, round the outside and then back through again.
Posted: Fri Feb 28, 2020 6:36 pm
by florian rudolf
Hello Guys,
thanks for helping.
The ferrit solution I will test soon.
The converter is an Chinees part, but in another modell (StuG 3) its working perfektly. also in my Sdfz251.
One of these converters I use is an 10Ah from 24 to 12V. Another one from 24 to 5V and 5Ah.
On the converter from 24-12V is the Benedini amplifier.
For testing I connected an seperate 10Ah converter on the Servo. - Having the same problem. - So I think its not an problem with the voltage.
Florian
Posted: Fri Feb 28, 2020 9:22 pm
by Christoffer Ahlfors
Hello Florian!
You mentioned already in the first post that it does not look like interference. It is like someone else is steering. Does the steering channel pass through the sound module? If so, have you tried to bypass the steering module? Could it be that you are using the wrong output from the sound module?
Posted: Sat Feb 29, 2020 11:03 am
by florian rudolf
Hello Christopher,
The steering channel is seperate from the sound, no connection point.
I have an micro servo for the steering wheel with an Y-cabel with the steering channel connected. the micro servo is having no inteferences. however I see no intefeence on it.
cheers
Florian
